Question: Installed sway and was wondering.....
Old Mar 6, 2005 | 05:50 PM
CIVICon14inBRWs's Avatar
Default Question: Installed sway and was wondering.....
My car is lower than 3" and i installed a GSR rear sway w/o any subframe reinforcement. took it for a drive and everything was okay, will i have any problems?? im worried because the sway seems to be stressed quite a bit cuz my car is really low. Any answer would be greatly appreciated. thanks!
Old Mar 6, 2005 | 06:03 PM
Farmer Brown's Avatar
Default Re: Question: Installed sway and was wondering..... (CIVICon14inBRWs)
Custom end links maybe for the sway bar?
I dont think there would be a real problem.
Old Mar 6, 2005 | 06:16 PM
AmginE's Avatar
there's been numerous horror stories of sways ripping out subframes. it's a generally good idea to install reinforcement, just in case. good luck otherwise.
Old Mar 6, 2005 | 06:18 PM
PLAN:B's Avatar
Default Re: Question: Installed sway and was wondering..... (AmginE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmginE &raquo;</TD></TR><TR><TD CLASS="quote">there's been numerous horror stories of sways ripping out subframes. it's a generally good idea to install reinforcement, just in case. good luck otherwise.</TD></TR></TABLE>
Nice hatch btw. It's clean
Old Mar 6, 2005 | 06:45 PM
red91sit's Avatar
Default Re: Question: Installed sway and was wondering..... (PLANBmotorsports)
Well it's mostly EK's that tear subframes, but i can't imagine ours being much stronger, The other thing is if your springs are harder than stock (which they pretty much have to be to be that low) the anti-roll bar puts a lot less strain on it's attachment points since much more work is done by the springs.
::EDIT:: BTW sexy car
Old Mar 6, 2005 | 06:46 PM
EARLdaSQUIRREL's Avatar
official honda whore
i doubt a gsr rear sway bar will ever rip out that frame, its like 15mm if i recall, and most people who have ripped theres are using 18-22 mm rears
Old Mar 6, 2005 | 06:47 PM
AmginE's Avatar
Default Re: Question: Installed sway and was wondering..... (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">i doubt a gsr rear sway bar will ever rip out that frame, its like 15mm if i recall, and most people who have ripped theres are using 18-22 mm rears</TD></TR></TABLE>
regardless of the 3mm difference, i'd do it for piece of mind.
but it's not my car, his decision.
Old Mar 6, 2005 | 06:50 PM
sinister6's Avatar
15mm wont tear off subframe..even 3000mm wont, the place where is tear off, is the rear cross member. if you want to go hardcore, weld the **** when you install it. Or, if you have the money to blow, put a DC2/EK9 for EG/EK.
Old Mar 6, 2005 | 06:51 PM
Luserkid's Avatar
Nothing wrong with getting a reinforcement brace but you dont need one. I have never heard of a EH ripping because of sway bars, its usually 96 and up. But thats also from serious driving, not daily.
Old Mar 6, 2005 | 06:56 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Question: Installed sway and was wondering..... (Luserkid)
Wait, the gsr rear sway (14mm) comes with it's own mounting bracket. There's the sway bar that attaches to the bushing bracket and that attaches to a square bracket thing that attaches to the subframe. Did you use all those parts?
Nice hatch.
Old Mar 7, 2005 | 12:14 AM
Default Re: Question: Installed sway and was wondering..... (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Wait, the gsr rear sway (14mm) comes with it's own mounting bracket. There's the sway bar that attaches to the bushing bracket and that attaches to a square bracket thing that attaches to the subframe. Did you use all those parts?
Nice hatch.</TD></TR></TABLE>
yes, i used all those pieces, my only main concern was if having my car too low would cause any harm, but judging from most replys i'll be fine. im getting 8k springs for the rear in a couple days so hopefully i'll be okay, btw, thanks for all the complements on the car.
Old Mar 7, 2005 | 12:33 AM
A.E Motoring's Avatar
clean *** hatch...where u get that wakaba sign?
Old Mar 7, 2005 | 01:24 AM
menkio's Avatar
just make a plate out of mild steel, recetangle that attacks from 1 side of the lca bolt to the other, then drill your holes for your sway bar mounts, etc.
bennyboie
Jun 15, 2009 07:43 AM
. a d a m
Suspension & Brakes
Feb 11, 2007 02:15 PM
JDM_dreamer
Jan 8, 2007 08:17 PM
young noob
Suspension & Brakes
24
Oct 22, 2006 11:11 PM
