NEED HELP: Hasport mounts in 91 CRX B16A
Old Mar 6, 2005 | 04:58 PM
B16CRXT's Avatar
Default NEED HELP: Hasport mounts in 91 CRX B16A
Ok, I tried all damn day today to swap my Place Racing mounts out for my new Hasports. Got the place racing mounts out, put all the hasports in except the rear mount. Took them all back out and tried to get the back one in but I cant seem to get the Bracket on teh mount and get the bolts to hold the mount to the crossmember.
Do I need a special Bracket? Anybody got some tips on what to do to get this **** in right? Would I be able to take the intake manifold off and drop the bracket right into place?
on a side note, somehow this fucked up my new 5000 pound SUV hydraulic jack...
TIA!
Old Mar 6, 2005 | 08:38 PM
brian g's Avatar
Default Re: NEED HELP: Hasport mounts in 91 CRX B16A (B16CRXT)
If you have the 90-93 Integra rear bracket it should be no problem fitting. Because the Hasport mounts move the engine back half an inch you may need to replace the rear mount first. You can unbolt the two bottom bolts on the rear bracket so you can swing it up and slide the mount in under it.
If that doesn't work, you can support the engine by a hoist or on a cart and disconnect all the mounts, Then move the engine slightly forward and install the rear mount and bracket.
brian g
Sammy Po
Jan 10, 2010 09:54 PM
88 EF Hatch
11
May 13, 2009 10:39 AM
tsopres
Mar 28, 2007 06:32 PM
Youlose1305
May 21, 2006 08:09 PM
B16CRXT
16
Mar 8, 2005 05:18 PM
