Throttle cable unhooked from gas pedal
Old Mar 6, 2005 | 04:12 PM
uncle's Avatar
Default Throttle cable unhooked from gas pedal
This is an h22 in a '97 civic EX. The cable has come undone from the pedal and I can't figure out how to tighten it at all. I am in need of the car right now so time is precious.
Old Mar 8, 2005 | 06:06 PM
blackeg's Avatar
Default Re: Throttle cable unhooked from gas pedal (uncle)
see if you can put it back on the gas while it is attatched to the throttle body. if that does not work, then see if u can fab a bracket to put more tension on the cable after you hook it to the pedal and tb, to keep it from comming loose again.
Mike Antonetz
Transmission & Drivetrain
Jun 3, 2019 10:10 PM
truxvi3tz
Mar 31, 2010 02:26 PM
91da9ls
Jan 29, 2007 04:00 AM
Yeung
Jun 3, 2004 09:12 PM
B2FiNiTY
11
Dec 2, 2003 01:37 PM
