keyless entry won't unlock but will lock when armed.
Old Mar 6, 2005 | 01:36 PM
limitedkorean's Avatar
Default keyless entry won't unlock but will lock when armed.
Hi I never posted here but yeah, my compustar keyless entry won't unlock when I disarm the alarm. It worked for awhile but now it won't. I am pretty new to the whole keyless entry bit so I really don't know that much about it. Any help is appreciated. I really miss keyless entry!!!! Thanks in advance.
Old Mar 6, 2005 | 01:42 PM
Default Re: keyless entry won't unlock but will lock when armed. (limitedkorean)
Oh woops, it is a 1994 Integra LS. Only mod done is ITR doors.
Old Mar 6, 2005 | 03:21 PM
Dogginator's Avatar
Daisy... Daisy...
You most likely have a disconnected ground wire from the relay operating the unlock feature.
Old Mar 6, 2005 | 05:14 PM
hatchinprogress's Avatar
Default Re: keyless entry won't unlock but will lock when armed. (Dogginator)
take off the door panel and check the auctuator mine has the same prob(but its not too much of an issue to me as long as it still locks)
Old Mar 6, 2005 | 06:11 PM
Well I will try your guys' advice tomorrow. Where is the actuator/ unlock relay? Hopefully it is just a ground problem. After never owning a power option ride.... I kind of like the whole idea of keyless entry. Thanks!
Old Mar 6, 2005 | 06:42 PM
I_dream_about_cars's Avatar
i didn't think you had to disarm the alarm, then unlock it. if it's keyless entry then you should be able to just unlock it and that will disarm it.
Old Mar 6, 2005 | 06:44 PM
EnjoyTheRideDC2's Avatar
Default Re: (limitedkorean)
the actuator is found inside the door close to the lock. The relay itself is on the drivers side door towards the mirror. Cant miss it....Brown box, bracketed onto the door, rectangle in shape...
Old Mar 6, 2005 | 06:48 PM
Default Re: (EnjoyTheRideDC2)
ONE MORE THING: Also look in the corner of the kick panel area, to the left of the clutch pedal, way in the corner. There should be a box behind the cruise control comp....usually installers use the plug from that control module to connect the lock and unlock wires on the alarm. maybe one was accidentally pulled???
Old Mar 7, 2005 | 11:08 AM
Deng yeh I am at school right now,but I had an extra brown box relay in my garage, replacing it did not do anything. I guess I will look for the actuator later today! I will check the kick panel area too, I did notice some wiring behind the plastic last time I was cleaning my car, hopefully that's the problem.
Old Mar 7, 2005 | 03:21 PM
when looking in the kick panel, Typically look for a blue and a green wire that has been tapped into the oem wires.
laziebun
Audio / Security / Video
11
Jan 23, 2011 04:16 PM
AARON RLH
Sep 16, 2008 02:15 PM
theeogflip
May 4, 2008 05:30 PM
slowturtle
Apr 29, 2005 06:59 AM
Hunter
Oct 27, 2002 08:02 PM
