b16 in a crx
Old Jan 21, 2002 | 11:13 PM
kwil666's Avatar
Default b16 in a crx
im sure you guys are a bit over questions about b16 in a crx, but i did a search and couldnt find out a few things. this is for a 88 crx.
1) not really sure what b16 to use b16a, b16a1, b16a2? also why use that year engine?
2) the only difference i can really tell between these engines are the trannys, but cant any b tranny bolt up to any b engine?
i think thats it can somebody shed some light on this for me thanks,
Keith
Old Jan 22, 2002 | 01:46 AM
CRX-RX's Avatar
Default Re: b16 in a crx (kwil666)
B16A1 is the cheapest/easiest option to use. It has the proper tranny mount locations to use a hasport mount kit, and the A1's cost considerably less than any other B16.
Old Jan 22, 2002 | 01:52 AM
AfEn808's Avatar
New User
Default Re: b16 in a crx (CRX-RX)
also the b16a1 is a first gen you can tell by looking at the head also not any bseries tranny bolts up you need a cable b series tranny.
Old Jan 22, 2002 | 05:37 AM
mooseknuckle's Avatar
If i were you, Id definatly put a b16a1 in your rex. Its not to expensive, and its the ideal motor for your car. Plus you'll run high 13's or low 14's
Old Jan 22, 2002 | 05:43 AM
EP3_05's Avatar
Default Re: b16 in a crx (mountaindru)
Use the b16a because there is no b16a1 and the b16a2/3 can be a pain to put into a non-obd car. It is just much easier to use the b16a.
Old Jan 22, 2002 | 12:00 PM
kwil666's Avatar
Ok now what about being smog legal?
It doesn't seem that hard to change the car to obd1 car (witch I believe the b16a2 is) its seems all I have to do is change the ECU the distributor and injectors.
As for the tranny issue anybody have any ideas on that?
i was thinking about using a b16a2 (from the del sol) and getting the mount kit from hasport. running it as a obd1 with ECU and injectors and distributor then using a cable tranny on it. what do you guys think im know im not the first to think of this.
thanks for your help so far
keith
Old Jan 22, 2002 | 03:20 PM
Rob!'s Avatar
Default Re: b16 in a crx (sEifUkU_eF)
how much would full b16a1 swap cost in putting into my91 crx hf?
Old Jan 22, 2002 | 04:46 PM
E-AT_me's Avatar
Default Re: b16 in a crx (RaceFacer)
depends on who you buy the motor from, which motor you use, what tranny you use, what mounts you need, what extras you need, what you decide to replace, what mount kit you use. anywhere from $2000 to about $10000.
Old Jan 22, 2002 | 04:51 PM
EP3_05's Avatar
Default Re: b16 in a crx (Rexman)
My swap: doing all the work myself
Full swap: Engine, trans, axles, ecu
Hasport mount kit, linkage and wiring
Thermostat
Water Pump
Timing belt
Fuel Filter
Wires and plugs
radiator hoses
new radiator
misc. gaskets
altenator belt and pulley
crank pulley
misc. parts required for the swap
edit: almost forgot the clutchmasters clutch
Total: 2800 and counting.
[Modified by 91civic, 8:58 PM 1/22/2002]
Old Jan 22, 2002 | 07:39 PM
max's Avatar
max
more like high to mid 14s
Old Jan 22, 2002 | 07:47 PM
big pete's Avatar
Default Re: b16 in a crx (max)
high 13s or low 14s maybe with some slicks
[Modified by big pete, 4:47 AM 1/23/2002]
Old Jan 22, 2002 | 07:52 PM
max's Avatar
max
Default Re: b16 in a crx (big pete)
on slicks, deffinetly will do low 14s
Old Jan 22, 2002 | 08:23 PM
kwil666's Avatar
Whats different when mounting a b16a2 then a b16a1? I looks like all you really have to do is buy a different mount kit, and convert the tranny to cable.
Old Jan 22, 2002 | 09:45 PM
customx_'s Avatar
New User
all the b series mount the same, the diff is the deck height to see if your valve cover bangs on the hood frame. you cant just get any tranny, you have to get a cable tranny unless you have more money to throw.
b16a2 is from usdm del sol vtec and 99-00 si.
b16a is from jdm 1st gen SiR and XSi. non-obd
someone correct me if im wrong.
Old Jan 22, 2002 | 11:21 PM
onefastcx's Avatar
get an sir 2 b16a 5 series it is the best one out there and yes you can put any b series trans with any b series motor
Old Jan 23, 2002 | 10:54 PM
kwil666's Avatar
Default Re: b16 in a crx (mindtrix)
Thanks for the info thats what I was looking for. Thanks again to all the replied.
Keith
Old Jan 24, 2002 | 12:44 AM
kwil666's Avatar
OK i have one more why is the deck height different as far as i can see the b16a and b16a2 are the same engine everything's the same on them hp, compression everything.
thanks again
keith
Old Jan 26, 2002 | 12:11 PM
afstlsvtec's Avatar
go with the b16a2 cause it is the engine out of the 92-95 civics and the have more power than the b16sir1,and will not have as many problems...
88crxdxfastwhip
Feb 19, 2007 03:26 AM
stockcolt
Apr 6, 2006 07:23 AM
B18aCRX
Aug 22, 2003 07:02 PM
mugensport9
19
Mar 24, 2003 09:31 PM
