B16A1 B16A Swap into 1988 88 '88 CRX Si
Old Mar 6, 2005 | 11:43 AM
RA122324's Avatar
Default B16A1 B16A Swap into 1988 88 '88 CRX Si
This was my first thread
Modified by knwldge54 at 8:07 PM 5/2/2007
Old Mar 6, 2005 | 12:01 PM
EP3_05's Avatar
Default Re: B16A1 B16A Swap into 1988 88 '88 CRX Si (knwldge54)
Do a search on here...b series swaps have been covered to death. Here is a barebones list though:
b16a engine, transmissions, ecu
mount kit and shift linkage (hasport, hcp, etc)
90-93 integra axles and intermediate shaft
Those are the basic parts but you will need other misc stuff and also maintenance parts like a clutch, water pump, timing belt etc
Old Mar 6, 2005 | 12:30 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: B16A1 B16A Swap into 1988 88 '88 CRX Si (91civic)
There are several links I posted in the FAQ section at the top
of this forum..
[You should read them all so that you can form some of your own opinions]
I spent over a year researching the swap and accumulating the parts..
Everything that I learned is referenced within the FAQ section..
[edit: including the wiring]
But if you have any specific questions,feel free to ask..
Modified by 88DXCRX at 4:05 PM 3/6/2005
Old Mar 6, 2005 | 12:34 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Do a search on here...b series swaps have been covered to death. Here is a barebones list though:
Those are the basic parts but you will need other misc stuff and also maintenance parts like a clutch, water pump, timing belt etc</TD></TR></TABLE>
what he said is exactly correct. the one thing he didnt mention is wiring. if your doing it yourself, then its fine. if not you can send it out to hasport or one of the many guys on here to do the conversion for you. its only a 4 wire difference.
do the rear main seal when you have the tranny out to do the clutch. trust me.
DreamOfTheFlood
Dec 23, 2007 12:49 PM
g2tegsown
Jul 1, 2005 01:30 PM
VspecSiR
Dec 12, 2002 07:17 PM
