Quirky Electrical System
Hi all. Need your expertise on this one. Sometimes my radio and fan don't work. I would turn on the radio or fan and nothing happens. I found that if I put slight pressure on the ignition, the radio and fan will work again. I didn't mind this, but after I installed a CD changer, the radio would sometimes click as if it was flickering off and on. Any suggestions? Thanks.
Slight pressure on the ignition? as in, turning the key a certain way? or pressing inward on the whole bit?
Anyway, if that is what solves the problem, it may be the switch itself is going quirky. If the car is under warranty, you probably should have taken it to the dealer about that before you put in the CD Changer.. as it is, there is still a slight chance that they won't automatically assume the CD changer is what caused whatever damage there is.
AgentJam
22
Mar 17, 2004 08:43 AM
