Need Help Installing GSR Girdle Into LS Block
Old Mar 6, 2005 | 08:56 AM
j87w's Avatar
Default Need Help Installing GSR Girdle Into LS Block
Im buying 5 gsr maincaps, the girdle, windage tray, oil pan, and the oil pickup. Im installing it on my 95 B18B LS block. What all am I going to have to do to put it in. I know im going to have to get the mains honed but anything else?
Old Mar 6, 2005 | 04:24 PM
j87w's Avatar
Default Re: Need Help Installing GSR Girdle Into LS Block (j87w)
bump anyone?
Old Mar 7, 2005 | 12:04 AM
j87w's Avatar
come on theres gotta be someone that can help me out here.
Old Mar 7, 2005 | 04:10 AM
NJIN BUILDR's Avatar
Bring your parts to the machine shop.They will check the size and make the necessary adjustments before they hone it.
Glenn
Old Mar 7, 2005 | 07:16 AM
j87w's Avatar
Default Re: Need Help Installing GSR Girdle Into LS Block (NJIN BUILDR)
Will it be anything thing major thats going to cost me alot of money?
Old Mar 7, 2005 | 02:59 PM
Have the shop your using give you a price.Should be less than $200.
Glenn
Old Mar 7, 2005 | 03:23 PM
j87w's Avatar
See the deal is, im trying to see if I can save money buying the one I found from a GSR setup, or buying the golden eagle kit. Dont you have to dowel the stock one or something?
Old Mar 7, 2005 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">Im buying 5 gsr maincaps, the girdle, windage tray, oil pan, and the oil pickup. Im installing it on my 95 B18B LS block. What all am I going to have to do to put it in. I know im going to have to get the mains honed but anything else? </TD></TR></TABLE>
If you get all the gsr parts,then all that has to be done is fit them to the block and align hone them.
Glenn
Old Mar 7, 2005 | 03:32 PM
acy76's Avatar
This is probably the definitive thread: https://honda-tech.com/zerothread?id=263598
Outlines the whole process using the stock LS caps.
j87w
Jun 24, 2013 06:20 PM
Unphzd
Oct 16, 2012 03:04 PM
xxmikexx206
Jan 8, 2007 09:08 AM
VTC_CiViC
Mar 8, 2005 11:12 AM
LBR92DA-T
Dec 20, 2003 02:23 AM
