B18 series B20 series Question!
Old Mar 6, 2005 | 08:03 AM
sleevedgsr's Avatar
Default B18 series B20 series Question!
Ok I have a B18C1 as of right now! The mileage is still ok im sitting at 127***, My main question is how long should I wait before getting a new motor? From what I hear a B20 is better than a B18? Is this true? What series are there in a B20 and what is the fastest and will it sit nicely in a 95 GSR?
Old Mar 6, 2005 | 09:28 AM
gsrious's Avatar
Default Re: B18 series B20 series Question! (sleevedgsr)
go with the long block b20 for the lowend tourqe. then later you can slap on a vtec head for those killer time slips.
Old Mar 6, 2005 | 09:45 AM
3.504's Avatar
Default Re: B18 series B20 series Question! (red dc2)
stick with the b18c1. just give it a re-build when it starts going bad. dont fix things that aren't broke.
any b-series can be just as fast as anyother. dont let people tell you ones better, they're all the same when built.
Old Mar 8, 2005 | 06:40 AM
sleevedgsr's Avatar
Default Re: B18 series B20 series Question! (3.504)
Ok, Thanks a Lot
Old Mar 8, 2005 | 06:47 AM
IggyBcool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">stick with the b18c1. just give it a re-build when it starts going bad. dont fix things that aren't broke.
any b-series can be just as fast as anyother. dont let people tell you ones better, they're all the same when built.</TD></TR></TABLE>
couldn't have put it any better. just stick with a motor that is from factory Vtec instead of trying to make a b20/vtec. a b16a2, b18c1, or b18c5 would be a lot more reliable and plus u can still mod it to be quicker and have more torque.
But if u insist of the b20/vtec lets look at it this way... the block about 600 bucks, b18c1 head 600ish bucks, building the block so it don't go boom when u take it over 7k about another 2k... ur just better off either rebuilding ur c1 or just buying a new c1 or c5..
Old Mar 8, 2005 | 06:56 AM
98lsskunk's Avatar
Default Re: B18 series B20 series Question! (99LStegra)
Why don't you buy a b20 block start building up the bottom-end, while you're doing that you will have a motor in your car. Once you finish your bottom-end start doing some work to the head of your gsr, when your done pull the C1 slap the head on the b20 block then you have a more powerful motor.
Old Mar 9, 2005 | 07:48 AM
sleevedgsr's Avatar
Default Re: B18 series B20 series Question! (98lsskunk)
Im not sure though. What is the differential of a b18c1 and a b18c5 in hp?
sleevedgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lsskunk &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you buy a b20 block start building up the bottom-end, while you're doing that you will have a motor in your car. Once you finish your bottom-end start doing some work to the head of your gsr, when your done pull the C1 slap the head on the b20 block then you have a more powerful motor.
Could I do the same with the C5 if I bought 1?
Old Mar 9, 2005 | 09:39 AM
98lsskunk's Avatar
if you had an itr motor i would just build that up
sekoo_88
Feb 26, 2014 01:23 PM
zeusdavis
28
Jan 8, 2011 03:51 PM
Corksil
10
Dec 29, 2009 10:11 PM
Ls91sI
Apr 22, 2005 03:18 PM
limpy
Dec 11, 2004 01:30 PM
