SRI vs. CAI
Old Mar 5, 2005 | 07:28 PM
txl146's Avatar
Default SRI vs. CAI
I am thinking about getting air intake system on my gen 4 lude. In comparing SRI and CAI, main advantage of having CAI is the fact that it's drawing colder air from side fender.
If you have two choices of intake, which one of these two would you choose?
1. Ebay CAI with K&N filter for $80
2. Apexi power intake for $90
Old Mar 5, 2005 | 07:46 PM
SUB-0 H23's Avatar
Default Re: SRI vs. CAI (txl146)
#1,
but personally i would remove the resonator on the stock intake and drop in a k&n filter
Old Mar 5, 2005 | 07:54 PM
Dougs96SI's Avatar
I vote #1 because its a CAI and not Short Ram. Ive had both, I have an AEM cold air on my lude and a Injen Short Ram on my Lancer, and I love the sound of the Short Ram, but i think that there is a little better performance in the CAI.
CAI also looks better under the hood anyways because you dont see the filter, looks great
Old Mar 5, 2005 | 08:03 PM
92SleeperH23's Avatar
I'd go with the A'pexi
K&N's only last so long, and need that lube stuff, and don't filter as well as Apexis
Check out this comparison - http://mkiv.com/techarticles/filters_test/2/
I guess you could get the best of both worlds and put that on the end of an ebay pipe, but it also fits on the factory pipe
Plus no risk of hydrolock
Old Mar 5, 2005 | 08:29 PM
PDM's Avatar
PDM
Default Re: SRI vs. CAI (92SleeperH23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SleeperH23 &raquo;</TD></TR><TR><TD CLASS="quote">I'd go with the A'pexi
Plus no risk of hydrolock</TD></TR></TABLE>
I cant believe you just posted that
Old Mar 5, 2005 | 08:37 PM
txl146's Avatar
Default Re: SRI vs. CAI (PDM)
From my experience with K&N filter, it tends to foul MAF sensor if oild too much. I'd probably go with Apexi with heat shield...
Old Mar 5, 2005 | 08:42 PM
DarkBB4's Avatar
honestly ive had both
Apexi Cold air intake (adding the apexi elbow and filter to an ebay SRI
and just the stock prelude intake arm wiht the apexi filter
I feel the apexi has more gains without the extention UNLESS its very hot out side and the sri loses alittle power
Old Mar 5, 2005 | 08:51 PM
txl146's Avatar
Default Re: SRI vs. CAI (DarkspeedVtec95)
Beside eBay, who carries Apexi for below $90?
Old Mar 5, 2005 | 09:00 PM
DarkBB4's Avatar
i could sell mine if I got a Zex filter for my nitrous
Even trade if u can find one
Old Mar 6, 2005 | 06:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDM &raquo;</TD></TR><TR><TD CLASS="quote">I cant believe you just posted that</TD></TR></TABLE>
Why? K&N's are supposed to be replaced like every 30,000 miles or so, Apexis are guaranteed for the life of the car
And K&N's are wet style, which means they must be cleand and do use a sort of filter lubrication crap, whereas Apexi filter is dry-type
Old Mar 6, 2005 | 07:27 PM
monalisa overdrive's Avatar
I actually read some comparison of CAI vs short ram a while back that showed surprisingly enough in many instances you will get more power under the curve benefit from a short ram than a CAI...i remember the Weapon R short ram was the best performing one...i think it was on h-t if anybody knows where it is lemme know
Old Mar 6, 2005 | 08:02 PM
PDM's Avatar
PDM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SleeperH23 &raquo;</TD></TR><TR><TD CLASS="quote">Why? K&N's are supposed to be replaced like every 30,000 miles or so, Apexis are guaranteed for the life of the car
And K&N's are wet style, which means they must be cleand and do use a sort of filter lubrication crap, whereas Apexi filter is dry-type</TD></TR></TABLE>
Replaced every 30,000? K&N filters are guaranteed for life (million miles) and are to be CLEANED every 30,000 (once a year or when the filter looks like it has a substantial amount of dirt on it)
periwinkle
Oct 10, 2005 06:22 PM
AKaccord
Apr 22, 2004 07:59 PM
dubxl152
Nov 30, 2002 06:38 PM
el_Presidente
Feb 11, 2002 05:34 PM
