stering shake at 7-mph braking
Old Mar 5, 2005 | 01:22 PM
mhmmofr0's Avatar
Default stering shake at 7-mph braking
hello
i have a 95 wiht 170k and the steringwheel has started shaking when you brake at 70mph it shakes side to side about 1/2 inch
i assume something is bent louse or warped on the front end but not quite sure where to look or what specifically may be the cause
any ideas?
tia
mark
Old Mar 5, 2005 | 01:35 PM
DubFat's Avatar
Default Re: stering shake at 7-mph braking (mhmmofr0)
this is a totally common occurence when breaking at high speeds with many cars...it's nothing to be worried about i don't think, but if you can avoid it, don't put as much pressure on the breaks and that should alleviate the problem
Old Mar 5, 2005 | 02:00 PM
JohnnyTequila's Avatar
Default Re: stering shake at 7-mph braking (DubFat)
dont know what he is talking about
check your rotors, they may be warped. might want to replace them.
Old Mar 5, 2005 | 03:13 PM
SuShiBoiiii's Avatar
Default Re: stering shake at 7-mph braking (JohnnyTequila)
yeah they are warped..you can prolly resurface them
Gsir8
Feb 3, 2007 09:30 PM
asept10
Dec 15, 2005 07:24 PM
1990hf
Mar 17, 2005 05:35 PM
Rocks
Jul 30, 2004 12:56 PM
91civicdx
Mar 31, 2003 06:06 AM
