Short Shifter Install
Old Mar 5, 2005 | 12:30 PM
Scantron's Avatar
Default Short Shifter Install
Just wondering on how to install a short shifter on my 91 civic Si.. Anyone have any websites that i could read off of,and is this something hard to do???
Old Mar 5, 2005 | 12:32 PM
Curtis2kul's Avatar
Default Re: Short Shifter Install (Scantron)
you really dont need any write-ups or anything! Once you get under the car you cant see how it works. Dont tighten the last bolt that goes through the shifter it self to tight or it will be really stiff. just dont get it to loose either
Old Mar 5, 2005 | 05:08 PM
b16sellout's Avatar
http://sportcompactcarweb.com/tech/0106scc_shift/
Old Mar 5, 2005 | 05:14 PM
Creepshow S60's Avatar
Default Re: Short Shifter Install (b16sellout)
i did it in 15 minutes without instructions. it's really pretty simple if you just logically take into account what you're doing.
FYI, the rubber piece under the shift boot can sometimes be a pain, but you need it on.
Old Mar 5, 2005 | 05:21 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Short Shifter Install (y-49CRX)
FYI:The link above makes it harder than it needs to be..
Inside the car,just remove the shifter ****..
Under the car,take out the bolts as numbered..
Old Mar 5, 2005 | 05:24 PM
progress's Avatar
I just changed my shifter this morning. When I bought my CRX, the previous owner cut down the stock shifter and it didn't seem to shift right. I took a stock uncut shifter from a CIvic at the junkyard a couple weeks ago and just installed it this morning. Easiest thing I've ever done! Those instructions in the above link are good to follow! Have fun!
Old Mar 5, 2005 | 05:58 PM
streetlegal gocart's Avatar
Default Re: (progress)
Vaguely and Noobily explained how i did it ...
Remove ****, shifter console; which has 4? screws , dust boot etc. Drop the midpipe from either end. remove the heatshield.
Remove the shifter rod pin and bolt. Remove some more random bolts . Then the three, which have no hex heads on top(sitting in the car you see them) just oval shaped; are a pain if they are rusted. Well remove those, drill them out if necessary and replace with regular bolts and nuts when reinstalling.
Pull out stock shifter. Installation opposite of removal blah blah... Use their rubber o-rings and bushings and lube up to prevent notchiness. Make sure shiftrod bolt is tightened good or you'll get stuck trying to find a nail to put in there when you're stuck on the highway after you pull over realizing you can't shift out/into gear lol.
Bend the heatshield if the shifter is hitting it/making noise.
lousy writeup, but gives u an idea what ur in for.
Old Mar 14, 2005 | 02:50 PM
JamesV's Avatar
Default Re: (Doctor Zagato)
k thanks.. now all i need is my damn short shifter.. freakin ebay people need to ship faster :9
jr408
Feb 12, 2008 12:13 PM
vietherbs
Apr 19, 2007 10:32 PM
SPOONup
Apr 27, 2004 09:22 AM
relic_sypher
Nov 12, 2001 04:47 PM
erikjohn19
Sep 28, 2001 10:48 AM
