Oil leaking from my distributor..
Old Mar 5, 2005 | 12:26 PM
LvN's Avatar
LvN
Default Oil leaking from my distributor..
I just installed a brand new distributor from distributor king on my motor. It's coming from the bottom part of the distributor. I tightened it and it still leaks oil. It's on my B18.
Old Mar 5, 2005 | 12:58 PM
Ninety5Ex's Avatar
Default Re: Oil leaking from my distributor.. (blkcivicpn0i)
could be your O-ring if that's what they call it. somebody just did a write up a few weeks ago search for it.
Old Mar 5, 2005 | 01:03 PM
2fast4u831's Avatar
I'm really 2slow
https://honda-tech.com/zerothread?id=1065831
Old Mar 5, 2005 | 01:11 PM
LvN's Avatar
LvN
Default Re: Oil leaking from my distributor.. (Ninety5Ex)
Distributor is BRAND NEW. O-ring is good.
Old Mar 5, 2005 | 01:17 PM
Stoich EG2's Avatar
try taking a picture. it could be that you installed it wrong. the 2 teeth could've been put in wrong (where it connects to the camshaft). might be 180 degrees off. either that or it just so happens there is a leak at the valve cover gasket
Old Mar 5, 2005 | 01:18 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">Distributor is BRAND NEW. O-ring is good.</TD></TR></TABLE>
wouldn't hurt to replace the O-ring again($2.22 part). parts are known to be defective from the factory from time to time you know. I had a Honda rebuild distributor that went bad as soon as it put in it.
Old Mar 5, 2005 | 07:13 PM
ajzeg's Avatar
Default Re: Oil leaking from my distributor.. (sleeperciv)
if its a slow leak we thought the leak on my b16 was comin from the distributor but it ended up it was comin from the seal on the vtec sylenoid that connects to the head and the top part of the sylenoid
Old Mar 5, 2005 | 07:38 PM
LvN's Avatar
LvN
Default Re: Oil leaking from my distributor.. (ajzeg)
It's a slow leak. Not too much, I'm thinking it might be the oil i rubbed on the dizzy before installing it. I'll wait a few days and see if it goes away. I sprayed simple green on the block before installing the dizzy. I did of course covered the necessary parts.
ribal_gh
Nov 10, 2012 10:00 AM
sonson6
Mar 20, 2007 07:56 PM
tca0bell
Oct 18, 2006 04:16 PM
thumbtack
Sep 1, 2004 08:29 PM
FMIDRC Racer
16
Oct 23, 2003 02:49 PM
