Suspension & Brakes Theory, alignment, spring rates....
energy bush for integra question
Old Mar 5, 2005 | 10:31 AM
Corinthians's Avatar
Default energy bush for integra question
I read somewhere that certain bush should use back original honda and certain bush should use pu or energy bush any idea which bush are surpose to be energy bush?
Old Mar 5, 2005 | 03:11 PM
Targa250R's Avatar
be professional
Default Re: energy bush for integra question (Corinthians)
The big rear trailing arm bushing should be either OEM Honda or Mugen rubber, because a solid polyurethane bushing does not allow the proper movement and will bind up under this application. Pretty much everything else can be poly with no adverse effects on suspension travel.
Old Mar 5, 2005 | 04:31 PM
Lord Helmet's Avatar
Default Re: energy bush for integra question (jeremyG2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremyG2teg &raquo;</TD></TR><TR><TD CLASS="quote">
"Could it be? Finally, a person more grammatically challenged than I!" - Bush </TD></TR></TABLE>
buhahahahaha
BTW original bushings will be fine for the daily driver.
Old Mar 5, 2005 | 08:04 PM
Slidingby's Avatar
^^ LOL, hate our commander and dork, but yeah that's all rumors about keeping one oem, that's just because someone else didn't pay for them all to be Poly-U.
Old Mar 5, 2005 | 08:12 PM
Targa250R's Avatar
be professional
Default Re: (civicyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicyndrome &raquo;</TD></TR><TR><TD CLASS="quote">^^ LOL, hate our commander and dork, but yeah that's all rumors about keeping one oem, that's just because someone else didn't pay for them all to be Poly-U. </TD></TR></TABLE>
Umm, okay, whatever.
FYI, Mugen rubber TA bushings are actually 4.5x more expensive than Energy's poly solution, and $15 more than Prothane's poly solution - and I'll still buy the Mugen bushings over poly, because they actually work properly. Honda designed that bushing a certain way for a reason.
Old Mar 5, 2005 | 08:16 PM
Default Re: (Targa250R)
more info please
Old Mar 5, 2005 | 08:25 PM
Targa250R's Avatar
be professional
Default Re: (Corinthians)
Here is all the tech information you could ever want on why you should use an OEM Honda or Mugen rubber bushing in the trailing arm instead of polyurethane:
https://honda-tech.com/zerothread?id=493789
https://honda-tech.com/zerothread?id=606414
Old Mar 6, 2005 | 06:09 AM
so beside this others should be fine with energy? and i am not planning to get the full set of the bush anyone mind to let me know which part i should get for the suspension? and any other parts that i should use energy
4DRmafia
Jun 5, 2006 07:16 PM
viper1984
21
Feb 28, 2006 06:21 AM
Corinthians
Mar 5, 2005 08:18 PM
Jeff99Base
Oct 12, 2004 07:04 AM
JookSingKid
13
May 3, 2004 09:08 PM
