Civic D15 rebuild
Old Mar 5, 2005 | 08:35 AM
Powered By Garrett's Avatar
Default Civic D15 rebuild
Well, my car continues to over heat, coolant just seems to dissapear and I pressure tested the radiator and it wasnt leaking, so I am thinking its the water pump (so i was told?) and maybe I have a blown head gasket. I drove the car today and it melted the hoses off the radiator overflow cap. Ive decided I want to replace the head gasket, water pump, overflow tank, all the hoses/cap for overflow, radiator cap, and i might look into a new radiator. Could anyone help me with the head gasket replacement? I searched but didnt find anything for a D15. Thanks!
Old Mar 5, 2005 | 08:59 AM
BauleyCivic's Avatar
Risky Business
Default Re: Civic D15 rebuild (EGtenchu)
Get a helms manual... http://www.helminc.com
I go over it lightly in my mini-me thread... https://honda-tech.com/zerothread?id=554053
Old Mar 5, 2005 | 09:00 AM
Default Re: Civic D15 rebuild (BauleyCivic)
Thank you sir.
Old Mar 5, 2005 | 09:35 AM
cockrummotorsport's Avatar
you need to check your block also. if the oil is a milky brown that means you block has a crank and the coolant may be leaking into the oil pan. that may explain why you can not find a coolant leak.
Old Mar 5, 2005 | 09:39 AM
Default Re: Civic D15 rebuild (cockrumracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cockrumracing &raquo;</TD></TR><TR><TD CLASS="quote">you need to check your block also. if the oil is a milky brown that means you block has a crank and the coolant may be leaking into the oil pan. that may explain why you can not find a coolant leak. </TD></TR></TABLE>
Only problem with that is if I have a blown head gasket i would have coolant leaking into the block also. why are cars such a pain?
panchlow
Jun 29, 2010 05:37 PM
masterkill455
May 21, 2009 10:18 PM
ssj4trunks09
19
Jan 13, 2008 04:21 PM
bomber19
Aug 5, 2007 06:57 PM
DC2SIR-G
Oct 3, 2005 06:34 PM
