si tranny
let me 1st say that i did a search and didn't find anything.
anyways , i'm about the buy a si tranny out of a 95 civic but my question is how would i know for sure that it is a si tranny? is there a numer or letters i should look for? i need help quick i'm supposed to get it today.
thanks in advance
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxstrikerxn »</TD></TR><TR><TD CLASS="quote">i recomend u go get the jdm d15b tranny or jdm d16a cuz their tranny have shorter gears n if ur lucky enuff u might get D series LSD
d15b trannys and ex/si trannys have identical gearing
</TD></TR></TABLE>d15b trannys and ex/si trannys have identical gearing
thanks alot for ur help guys. well i got both of them is one better than the other? i think the s20 came out of a 94 cx and i dont know what the s40 came out of. i need to put a tranny in my car but i dont know which one i should put in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">s40 for sure! its an ex tranny from 96-00 </TD></TR></TABLE>
Best d-series tranny there is... steel shifter forks.
Paper thin steel shift forks... I've been through 2 1-2 shift forks and two sets of bearings already. I've since gone back to a 94si tranny that I had laying around. Threw new bearings and seals in i t and its been going for 15,000mi already. Thats about double any of the ek trannies went.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viteg »</TD></TR><TR><TD CLASS="quote">so i guess ex it is, will the dx axles from an auto work with the tranny?
Yah i also want to know if auto axles work with manual trannys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">Paper thin steel shift forks... I've been through 2 1-2 shift forks and two sets of bearings already. I've since gone back to a 94si tranny that I had laying around. Threw new bearings and seals in i t and its been going for 15,000mi already. Thats about double any of the ek trannies went.</TD></TR></TABLE>
Maybe you should learn how to shift correctly? It's no fun breaking a piece off your aluminum shifter fork when your street racing 100 miles from home. I will never run a tranny with aluminum shifter forks again.
http://www.homemadeturbo.com/f...00725
i think the tranny in a 93 si would be a s40 also. the guy who i got mine from said it was from a 95 si.
Can some one tell me if the auto axles from my dx will fit in the manual si tranny?
did you know you should use the clutch when shifting at 7000 rpm???
Can some one tell me if the auto axles from my dx will fit in the manual si tranny?</TD></TR></TABLE>
Yes
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
I thought the passenger side was shorter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifty35 »</TD></TR><TR><TD CLASS="quote">
I thought the passenger side was shorter?</TD></TR></TABLE>
PLEASE tell me this isn't true.
Uh, to my knowledge they are the same.
Go cross-check part #'s at http://www.slhondaparts.com to be sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Uh, to my knowledge they are the same.
Go cross-check part #'s at http://www.slhondaparts.com to be sure.</TD></TR></TABLE>
My bad... they are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viteg »</TD></TR><TR><TD CLASS="quote">i think the tranny in a 93 si would be a s40 also. the guy who i got mine from said it was from a 95 si.</TD></TR></TABLE>
92-95 EX/SI tranny's are s20 and they have aluminum shifter forks. The 96-00 EX tranny's are s40 and they have steel shifter forks.
