:::::::::Advice on Exhaust pipe size 2.25inch vs 2.5inch::::::::
there are so many exhaust to pick from..size,design,sound.....
the mode on my car is short ram intake so far..and not really plan to get engine upgrade, such as Cams,Came gears....
for a GSR what exhaust size will flow good also fine gain (also trying match up with header and car)
so what should i pick? 2.25inch or 2.38 or 2.5inch
any advice will help, thank you
Modified by Chris DC2 at 1:06 AM 3/5/2005
it all depends on your peak hp goals. sounds like you aren't going to do much more than breathing mods. 2.25 should be fine
on stock motor..will 2.25 and 2.5 get off same HP?
what is back-pressure? from bigger pipe problem? or smaller pipe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 »</TD></TR><TR><TD CLASS="quote">2.5 inch piping with stock motor or some bolt on(I/H/E) will actually lose some low end power.. </TD></TR></TABLE>
hmm..like under 4k? well..honda's are all about High PRM isnt it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuyImports2 »</TD></TR><TR><TD CLASS="quote">what are you saying? that you want the 2.5 anyway and that you plan to never be under 4k?</TD></TR></TABLE>
no iam saying there is different gain(stock motor) on 2.25-2.38 or 2.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">not really plan to get engine upgrade, such as Cams,Came gears....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">for a GSR what exhaust size will flow good also fine gain (also trying match up with header and car)
so what should i pick? 2.25inch or 2.38 or 2.5inch </TD></TR></TABLE>
2.25 will suit ur need the most..get a header with 2.25 collector too...
FYI, stock itr catback is 2.25..
right but why lose the little power you have under the 4k for very little or No applicable gain in the high end
</TD></TR></TABLE>right but why lose the little power you have under the 4k for very little or No applicable gain in the high end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 »</TD></TR><TR><TD CLASS="quote">^ it really depends on ur WHP goal... 2.25 will handle 190whp with no problem..</TD></TR></TABLE>
so at what whp goal would you recommend to upgrade to a 2.5" ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redxalien »</TD></TR><TR><TD CLASS="quote">
so at what whp goal would you recommend to upgrade to a 2.5" ?</TD></TR></TABLE>
200+ imo
200+ imo
people saying 2.5 is better..cause of air flow is better..i can see 2.5 will flow better than 2.25 or 2.38 . will there bad effect on 2.5 on basic setup engine? (I/H/E)
There have been some good posts in here. Remember: your engine comes down to being one thing only; a big over working air pump. The more air you can get in and out as efficiently as possible the better. Also like the guy mentioned before, there are harmonic pulses that work in your benifit to help rid the system of exhaust gases more effciently. Mess up the harmonics and you get unwanted back pressure and hp loss. I really don't think 2.5 would be such a bad thing at 190whp or so.
Once you get into turbo charging then 2.5 will be of no use. For now, it will work for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">
Once you get into turbo charging then 2.5 will be of no use. For now, it will work for you.</TD></TR></TABLE>
Have to disagree with you on that one. On a greddy kit 2.5 would be just fine. Now on a larger setup, like a drag setup 3" would work better... Don't forget we still have 1.8 L 4 cylinders
(well most of us )
(well most of us )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">people saying 2.5 is better..cause of air flow is better..i can see 2.5 will flow better than 2.25 or 2.38 . will there bad effect on 2.5 on basic setup engine? (I/H/E)</TD></TR></TABLE>
2.5 is better for the air to flow but the question is do u have such amount of air to flow in a 2.5 piping?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 »</TD></TR><TR><TD CLASS="quote">2.25 will suit ur need the most..get a header with 2.25 collector too...
I thought that all headers have either a 2" collector or a 2.5" collector. At least that is what all the headers that I see being sold have. Which header would someone pair a 2.25" exhaust with?
Here are some specs that I've been looking at from Team Integra:
http://www.team-integra.net/se...D=793
</TD></TR></TABLE>I thought that all headers have either a 2" collector or a 2.5" collector. At least that is what all the headers that I see being sold have. Which header would someone pair a 2.25" exhaust with?
it doesn't matter thaaaat much if you aren't going to be racing. judging that you just did intake i guess your not. the losses and gains people are talking about are minimal. take your time picking out your exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict »</TD></TR><TR><TD CLASS="quote">it doesn't matter thaaaat much if you aren't going to be racing. judging that you just did intake i guess your not. the losses and gains people are talking about are minimal. take your time picking out your exhaust.</TD></TR></TABLE>
yes..only mode intake.lol cheaposs owner.. i was thinking T1R power exhaust 63mm(2.5inch) about $680..
i would just get any 60mm exhaust u like, and not worry about the 60mm too much, get one that appeals to ur style and sound.
im here runnin a factory gsr header and gsr exhaust that got crushed in a accident
anything would be better then that for a motor modded like mine.
