oil pressure?
i have a ls/vtec with a gsr oil pump. when i am going around 70mph my oil is at 75psi then today about 1 hour ago i got back on the freeway and my oil pressure would not go higher than 65psi is that a propblem or should i just ferget about it.
thanks!
thanks!
just be glad you have that much!
Im getting 0 at idle, 40 max.
Fresh rebuilt b18c1
Ive tried ******* everything, Replaced pickup gasket, replace engine oil with thicker oil to see if i could get more pressure, replace new oil pump with old one to see if the new oil pump was bad.
All i have left is
next to pulling the motor back out to check all the bearings.
Fresh rebuilt b18c1
All i have left is
this happend to me right before my old b16a gave out, pressure kept dropping in 7-10 psi increments, my new motor is pushing roughly 85 psi at highway speed
