my 96 EK smells like gas. smells like its comming from the back seat area...
Old Mar 4, 2005 | 09:27 PM
whitemike1644's Avatar
Default my 96 EK smells like gas. smells like its comming from the back seat area...
my whole car smells like gas and today i reached into the back seat to get something out and i noticed it stronger towards the back of the car.
whats wrong? i have like 130k and i have never changed anything with the fuel system or antyhing like that, it still has the Y7 and everything.
Old Mar 4, 2005 | 09:32 PM
civictildeath's Avatar
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (whitemike1644)
take the lower part of the back seat out and make sure the seal for the gas tank there is tight
Old Mar 4, 2005 | 09:53 PM
gt25CIVICex's Avatar
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (civictildeath)
it sound like it could be coming from the fuel pump access
Old Mar 4, 2005 | 10:22 PM
SOHC4life 96's Avatar
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (gt25CIVICex)
Yeah, I'm betting your fuel pump is about to go. Get it checked out. If you drive long enough and the pump gets hot enough it will most likely stop working.
Old Mar 5, 2005 | 04:59 AM
gsrpoweredcivic's Avatar
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (SOHC4life 96)
it happened to a friend of mine and it was that he left his gas cap off
Old Mar 5, 2005 | 10:05 AM
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (gsrpoweredcivic)
naw i always put my gas cap on........and i am thinking it could be the fuel pump i mean i am pushing 130k-140k on the car, and i also noticed that even when i start the car like i will be on a flat level and like upto a half of tank of gas and it takes a minute to start like it cranks quite a few times, and i already replaced the alt. and starter. so i am thinking there is not enough pressure going through the gas lines which would obviously point to the fuel pump.
Old Mar 5, 2005 | 10:44 AM
SirRevvs's Avatar
Take the lower back seat out and excamine the fuel pump area. Make sure all bolts are tight. Not sure how a fuel pump going bad could make your car smell like gas . Sounds like something isn't secure with the pump access lid.
Old Mar 5, 2005 | 02:22 PM
Default Re: my 96 EK smells like gas. smells like its comming from the back seat area... (SirRevvs)
aite i will just do that then.......problem is i don't have a second car to use if i take it to get checked
Old Mar 5, 2005 | 03:03 PM
Weapon_R's Avatar
If its from the back seat, best bet is to take out the bench and see if the seal is gone. You'll be able to smell it.
Also, remember that your gas tank is in the back - perhaps a damaged tank?
domrw
Honda Civic (2001 - 2005)
10
Mar 2, 2017 06:40 AM
dephtone
24
May 17, 2011 05:19 AM
scarcha
Jan 13, 2011 12:25 PM
tanabe
Jun 14, 2007 02:26 PM
dizzyroc88
25
Dec 2, 2006 05:13 AM
