exhaust sounding a little weird....
Old Mar 4, 2005 | 09:08 PM
cSpEk's Avatar
Default exhaust sounding a little weird....
Well i just installed a greddy 4-2-1 header on my 99 si as soon as i started to test drive it i heard some what of a sputtering sound..i don't kno what it is but is it supposed to make that sound or i have a leak or something, if i get on the gas the sputtering will get louder and busier but if i drive pretty calm the sounds not there someone help!
Old Mar 4, 2005 | 09:21 PM
Aespooncivic's Avatar
Default Re: exhaust sounding a little weird.... (cSpEk)
u put that metal gasket on the header?
Old Mar 5, 2005 | 08:32 AM
cSpEk's Avatar
yea i did
Old Mar 5, 2005 | 10:08 AM
LShatchie's Avatar
Default Re: (cSpEk)
sounds like you have a leak, the more gas u give it the more exhaust you motor creates hence making the leak louder
did you make sure it was tightened real good?
Old Mar 5, 2005 | 10:41 AM
SirRevvs's Avatar
Default Re: (civichatch6989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch6989 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have a leak, the more gas u give it the more exhaust you motor creates hence making the leak louder
did you make sure it was tightened real good? </TD></TR></TABLE>
What he said.
Old Mar 5, 2005 | 11:21 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (SirRevvs)
yeah, it's a leak.
Old Mar 6, 2005 | 09:10 AM
cSpEk's Avatar
its tightened pretty damn good, the sputter actually doesn't sound like it gets louder as i give it more gas it just sounds like it's there
Old Mar 6, 2005 | 09:12 AM
cSpEk's Avatar
where would i most likely check for the leak?
Old Mar 6, 2005 | 09:49 AM
ThatsMyEG's Avatar
Default Re: (cSpEk)
what size piping do you have? maybe back pressure..
Old Mar 6, 2005 | 10:12 AM
Fugeeu's Avatar
Default Re: (ThatsMyEG)
is it kind of a popping sound?
Old Mar 6, 2005 | 04:18 PM
urquidezj's Avatar
Default Re: (Fugeeu)
check the doughnut (or whatever u call it) where the header ends and cat starts maybe thats loose. if its a 2 peace check the section where the top part of the header and the downpipe meet. those are the only places that it can be loose.
Old Mar 6, 2005 | 04:22 PM
b18civic1993's Avatar
i would check the gasket and make sure its seated all the way around and make sure that no little particles of anything are in there causing it to leave a small hole letting exhaust gass's leak out.
Old Mar 6, 2005 | 06:59 PM
cSpEk's Avatar
i have 2.25 piping with hks titanium high power
allricedout
Mar 14, 2007 06:33 PM
Slowboy!
16
Jan 12, 2006 09:58 AM
EKautox
Aug 18, 2005 09:16 AM
StolenTeg
Oct 31, 2004 01:57 PM
civic91
Jan 20, 2004 05:51 PM
