steering wheel shakes while in braking progess...?
Old Mar 4, 2005 | 08:21 PM
GsR-Freak's Avatar
Default steering wheel shakes while in braking progess...?
during high or local driving at somewhat 40-80, when apply semi-forced the brakes down (not slamming) the steering shakes a little or more than a little meaning?
anyone have any ideas?
Old Mar 4, 2005 | 08:30 PM
r3v da t3g's Avatar
Default Re: steering wheel shakes while in braking progess...? (GsR-Freak)
I had a similar problem and I found the problem, that my brakes werent being applied evenly that only one side would hit the rotors causing vibrations, but i dont know how to fix it i let my cousin fix it
Old Mar 4, 2005 | 08:42 PM
2ndgentegracer's Avatar
Default Re: steering wheel shakes while in braking progess...? (r3v da t3g)
Could it be warped rotors? Have you checked them out, I know my Teg shakes a little bit when I brake, but it needs new ones.
Old Mar 4, 2005 | 08:59 PM
SYTFU Tommy.'s Avatar
Default Re: steering wheel shakes while in braking progess...? (2ndgentegracer)
need new rotors thats all. happened to me before.
Old Mar 4, 2005 | 09:36 PM
virusiidx's Avatar
maybe you can just resurface them
Old Mar 4, 2005 | 11:01 PM
vjace's Avatar
Default Re: (virusiidx)
the rears r to thin to resurface the front one it depends how bad their warped mine r shot i say screw it man whats a little shake here and their just use your gears man
Old Mar 4, 2005 | 11:14 PM
91TegLS's Avatar
Default Re: (vjace)
Brakes are cheaper than clutches. Not to mention trannies or engines.
Old Mar 5, 2005 | 06:49 AM
flukeDC4's Avatar
Default Re: (91TegLS)
Id deffinitely say its rotors.. Rotors are cheap and easy to replace as are brake pads..
Old Mar 5, 2005 | 11:02 AM
95_GSmokeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">Brakes are cheaper than clutches. Not to mention trannies or engines.</TD></TR></TABLE>
Absolutely. I second this.
glulude
May 1, 2007 04:57 PM
da_33
Mar 27, 2007 12:51 PM
AViciousTHRUST
Apr 2, 2006 08:30 AM
civiceg500
10
Sep 10, 2004 07:38 PM
zseeanz
Mar 24, 2004 02:41 PM
