My LS All Motor Build...quick question
Well my tranny finally gave up, got another ys1 tranny which im going to rebuild with new syncros, and get a flywheel. Since im going to have my car sitting for a while HEHE i wanna build it slow. Here's wut im thinking:
Pr3 or p30 pistons
ACL or OEM bearings
OEM gasket kit
Shave the head a bit
Valve Job
Chip my ECU
Do a bit of tuning
This is for right now and get it running again.
Do you think this will be a good set-up maybe put down about 150 horses to the wheel or more.
Let me know and give me some more input.
Thanks in advance
Pr3 or p30 pistons
ACL or OEM bearings
OEM gasket kit
Valve Job
Chip my ECU
Do a bit of tuning
Thanks in advance
with a set of p30's a head mill, header and a new intake manifold/throttle body combo you should come fairly close to your goal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 »</TD></TR><TR><TD CLASS="quote">with a set of p30's a head mill, header and a new intake manifold/throttle body combo you should come fairly close to your goal.</TD></TR></TABLE>
I say withthat he gets about 130ish
I'm doing a budget build and have posted my parts on http://www.nonvtec.com PR3 pistons,Cams(404's),SK2 IM,valve train,Nice header, + TUNING will get you closer to 150whp look up user Hybrid_vtec set up. One of the nicest I've seen for a LS. 170whp
With that setup, you will be under cammed, so I would look into camsfor your engine as well and choose one that is going to help you reach your goal! Alsothe cam you choose has to relate with how you drive the car. Daily or weekend driver?
Crower 403 or Crane #16 for daily driving
Crower 404 or Crane #18 for more of a race application/weekend car
If you have any questions, I am willing to help.
SIICKK thanks
well yea i was thinking of getting cams (crower 404's) but i dont think ill havea enough money for them but my goal is to run a low 14s on street tire and street trim.
Does any one have any dyno graphs with the set-up
Thatll help me alot
ANd again thanks for the help
Thatll help me alot
don't have a dyno to show but i dynoed about 155 and think 126 tq with crower 404's I/H/Cat/E 2.5inch piping, universal muffler, SAFC, msd ignition, cam gears, aem pulleys, and would have been higher but i have low compression, with your block build and cams you will easily put down 150
wut compression do the 94 and up integra pistons have, does any ls motor have this set-up, thinking of getting them from some guy in H-I.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92bluteg_ls »</TD></TR><TR><TD CLASS="quote">wut compression do the 94 and up integra pistons have, does any ls motor have this set-up, thinking of getting them from some guy in H-I.</TD></TR></TABLE>
All B18a/b's have a 9.2:1 Compression Ratio, but he dynamic will be much lower than stock whenyou go with the bigger cams, so bumping the compression is almost a must.
My bad i ment the 94 and up gsr, wut compression fo they have? I can get them for 50 bucks from some guy in houston.
Oh yea *** for my build goes
(Transmission)
I ordered my Carbon Syncros 3,4,and 5th gear - gear-speed.com
Ordered the bearings and rebuilt kit too from them - gear-speed.com
Engine:
Took off the head and all and its clean just to clean it a bit and polish it up
Dont have too much done due to my payments and child support but ill get there.
(Transmission)
Engine:
if you want about 150 without touching the bottom end, mill the head down a LOT. get some 404s (they are small cams IMO), headwork, nice IM, nice header (herein lies your power window), hondata or other tuning system, and maybe a couple bolt ons and you should be just approaching the 150 mark
Kool thanks guys, Some guy was selling some 404's for 350 used but i didnt have the money in hands if not i would of have bought them.
But since i have to replace some piston rings might as well get the p30's(if you know where I can get some for a good price lemme know)
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92bluteg_ls »</TD></TR><TR><TD CLASS="quote">Kool thanks guys, Some guy was selling some 404's for 350 used but i didnt have the money in hands if not i would of have bought them.
Thanks</TD></TR></TABLE>
look in the classified on http://www.nonvtec.com
I think someone has a set of P30's or PR3's for cheap.
