1 wire to 4 wire o2 sensor
Old Mar 4, 2005 | 07:46 PM
GSX TO CX's Avatar
Default 1 wire to 4 wire o2 sensor
I have a 93 cx with a d15b8 engine wth about 125,000 miles. I recently got a code 43. I searched and found most people believe that means a bad o2 sensor. The car seams to drive fine and on a recent road trip right before I threw the code I got about 36 mpg. My question is should I change the o2, and would there be any benefit in using a 4 wire heated o2 instead of the 1 wire I have now. Is that possible? Any help would be appreciated.
Old Mar 4, 2005 | 08:58 PM
ReDHaTcHyGuy's Avatar
Default Re: 1 wire to 4 wire o2 sensor (GSX TO CX)
if u are using the stock cx ecu , there would be no point of doing it cause that ecu is setup for 1 wire O2.. unless u got the code after u put a different ecu in
Old Mar 4, 2005 | 09:05 PM
Donkey85's Avatar
Default Re: 1 wire to 4 wire o2 sensor (ReDHaTcHy97)
if you put a 1 wire where a 4 wire is saposed to be you will get a check engine light all the time as well as shitty gas mileage
Old Mar 5, 2005 | 10:11 AM
LShatchie's Avatar
Default Re: 1 wire to 4 wire o2 sensor (Donkey85)
yeah keep the 1 wire o2
lv6l
Dec 14, 2005 04:04 PM
StupidSlowRSX
Mar 3, 2005 07:54 AM
89dohcEF
20
Dec 7, 2003 02:07 AM
Frankinfreak300
Sep 27, 2003 08:43 AM
FusionITR
Feb 28, 2002 11:50 PM
