Air Blow Bye On Plug Wire ????
Old Mar 4, 2005 | 05:39 PM
ViZ's Avatar
ViZ
Default Air Blow Bye On Plug Wire ????
I am getting air blowing from the spark plug hole.. it seams that the wire isnt sitting all the way down and when i push the cap with a screwdriver so it closes the hole better the sound gets quiet or stops..
i pulled the wire and there is no oil aroound it at all.. does air normally blow through here and the cap just isnt sealing? or do you think the spark plug isnt sealing in tight for some reason??
im going to pull the spark plug and check it but anyone have any insite?
btw this is an h22
Thanks
Old Mar 4, 2005 | 08:13 PM
Shizznaz's Avatar
Default Re: Air Blow Bye On Plug Wire ???? (ViZ)
Doesnt sound normal to me. After all, why should there be air movement in there? It should be completely sealed
Old Mar 5, 2005 | 09:36 AM
Perfectionist's Avatar
It's either crankcase pressure blowing through the rubber O-ring seal under the valve cover or it's cylinder pressure blowing up through the spark plug threads.
If it's a puff-puff flow, it's likely cylinder gasses leaking up past the threads.
If it's a smoother stream, it's crankcase pressure. Take off the oil filler cap while it's idling and see if the air flow stops.
Old Mar 7, 2005 | 02:16 PM
ViZ's Avatar
ViZ
Default Re: Air Blow Bye On Plug Wire ???? (Perfectionist)
its not the crank case i know that, i tried the pcv valve and the oil cap
my spark plug was loose
i tightened it and well after a day it loosened again.. =\ and its not fealing so hot when i tighten it.. im going to change the plugs.. what can loosen them like that and why just cylinder 2?
Old Mar 7, 2005 | 03:41 PM
Shizznaz's Avatar
it might just be a bad spark plug. But yeah most definatly change them.
Old Mar 8, 2005 | 08:51 PM
PURPLETERROR aka BIGMATT's Avatar
hopefully its just a bad plug and your threads are not messed up. get a set of ngk's and you should be fine
NocTurNalFX
Feb 18, 2011 09:45 PM
nix94delsol
May 1, 2009 01:16 PM
LoudLude
Jan 20, 2006 03:36 PM
lethalgsr32
Dec 31, 2005 03:50 PM
Yokohama
12
Jul 2, 2003 12:59 AM
