B16 Swap-VSS Question
Old Mar 4, 2005 | 05:17 PM
swifty4u's Avatar
Default B16 Swap-VSS Question
I searched, but couldn't really find a direct answer. My friend is swapping his 90 hf with a jdm b16. The speed sensor on his car is mechanical(?) and the one on the b16 is electric. I see that you can just switch the electric one with the one from the crx, but then would vtec work because the ecu isnt gettin the signal for the speed? Would you be able to wire it up anyway? They just called me and asked to look it up..so I cant go and look at the car.
ANY help appreciated!
Old Mar 5, 2005 | 08:35 AM
swifty4u's Avatar
Default Re: B16 Swap-VSS Question (swifty4u)
Turns out a DA VSS works because it is both electrical and cable.
Old Mar 5, 2005 | 09:02 AM
daidilus's Avatar
LOL
you could have just taken the old one from your D-series tranny...pops right in
Old Mar 5, 2005 | 09:06 AM
dr_latino999's Avatar
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">LOL
you could have just taken the old one from your D-series tranny...pops right in</TD></TR></TABLE>
He could have, but then there would be no ECU activated VTEC
Old Mar 5, 2005 | 10:42 AM
swifty4u's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">He could have, but then there would be no ECU activated VTEC </TD></TR></TABLE>
Yep..could I have just used a RPM activated switch if I had one? For the VTEC that is.
Old Mar 5, 2005 | 10:54 AM
crxtreme89h's Avatar
Have you had any luck popping the VSS out of the HF tranny before? It's a pain in the ***. I never got mine out.
Old Mar 5, 2005 | 01:25 PM
daidilus's Avatar
where do you get your information from????????
i am using the cable actuated VSS from my Si tranny......the electronic part is in the cluster.......it works.....or my rex would not have vtec....
Old Mar 5, 2005 | 01:40 PM
90civichbsi's Avatar
what he said one post up.... theres still a signal wire from the cluster that goes to the ecu for speed signal on your stock cluster. so the d series vss works fine.
Old Mar 5, 2005 | 03:45 PM
swifty4u's Avatar
Default Re: (90civichbsi)
So, could I use the one from the DA, the part that goes into the tranny. It will hook up to the b16 ecu no problem? No cel and + vtec?
Thanks guys
So..The d-series vss will work to run the ecu, but then will the speedo work? Isn't that cable driven? Sorry if im confusing the heck out of ya's..but just trying to get this to work right.
Modified by swifty4u at 7:57 PM 3/5/2005
Old Mar 5, 2005 | 04:32 PM
daidilus's Avatar
just hook it all up like stock....use your original VSS, and cable....everything will work fine
Old Mar 5, 2005 | 06:25 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">just hook it all up like stock....use your original VSS, and cable....everything will work fine</TD></TR></TABLE>
Werd!
Old Mar 6, 2005 | 04:03 PM
krazie1's Avatar
BANNED
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Werd! </TD></TR></TABLE>
Old Mar 6, 2005 | 04:04 PM
krazie1's Avatar
BANNED
Default Re: (krazie1)
all cable driven VSS will work
e jay one
Jan 13, 2007 09:31 PM
1990_CRX_Kid
Jun 14, 2005 04:21 PM
davidcrx89
15
Feb 17, 2005 09:55 PM
blackmagicCRX
20
Feb 14, 2005 10:37 AM
riceball777
Jun 1, 2003 01:46 AM
