What am i missing? b16 rebuild.
Old Mar 4, 2005 | 03:42 PM
NotPhilTran's Avatar
Default What am i missing? b16 rebuild.
rebuilding a b16 with .5mm overbore
I just bought
arp headstuds
arp main studs
acl bearing kit
arias pistons
scat rods
i need
honda gasket set
water pump
oil pump
timing belt.
can you guys think of anyhthing im missing?
Old Mar 4, 2005 | 10:15 PM
PrettyLude's Avatar
get everything balanced
Old Mar 5, 2005 | 03:33 AM
Default Re: (PrettyLude)
thank you
anything else?
Old Mar 6, 2005 | 12:08 PM
biotech0123's Avatar
Default Re: (NotPhilTran)
is the top end stock?
Old Mar 8, 2005 | 05:29 AM
Default Re: (biotech0123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 &raquo;</TD></TR><TR><TD CLASS="quote">is the top end stock?</TD></TR></TABLE>
yes it is for now.
which engine do i get my bottom end gasket kit for?
obd 0 dohc vtec head
jdm b16a2 block
Old Mar 8, 2005 | 05:54 AM
NJIN BUILDR's Avatar
Same gaskets.
Glenn
Old Mar 8, 2005 | 10:35 AM
rjay8604's Avatar
Default Re: (NJIN BUILDR)
crank micropolished. You'll probably want a new clutch too, thats up to you though.
Old Mar 8, 2005 | 01:52 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: What am i missing? b16 rebuild. (NotPhilTran)
timing belt tensioner, valveguide seals
Old Mar 8, 2005 | 06:21 PM
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">crank micropolished. You'll probably want a new clutch too, thats up to you though.</TD></TR></TABLE>
ya crank polished is about 40 bucks.
Old Mar 9, 2005 | 05:59 AM
tgreaves's Avatar
Default Re: What am i missing? b16 rebuild. (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">timing belt tensioner, valveguide seals</TD></TR></TABLE>
Was about to say that..
Old Mar 17, 2005 | 05:31 AM
Default Re: What am i missing? b16 rebuild. (tgreaves)
how much is a new timing belt tensionor from honda.?
Old Mar 17, 2005 | 05:46 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran &raquo;</TD></TR><TR><TD CLASS="quote">how much is a new timing belt tensionor from honda.?</TD></TR></TABLE>
Too much.. There is a website that sells them for like $20 or so, but I forgot what it was.. Do a search on here for the tensioners and youll find it..
Old Mar 31, 2005 | 08:19 PM
willie_su2166's Avatar
As a friend of you, and honest to you
"Find Someone have actually experience to put it together or do research and do yourself" and "do it in the right way intead of cheap way"
Thanks
Will
Old Apr 1, 2005 | 11:11 AM
Default Re: What am i missing? b16 rebuild. (willie_su2166)
thanks will the engine has already been assembled by a very good machinist here in lincoln. all i have to do is put it back in.
InTheLBC20
Mar 27, 2010 04:24 PM
egb16pg
Jul 25, 2007 01:35 AM
hotimportcrx
Sep 16, 2005 11:04 AM
Grand
Mar 28, 2005 02:00 PM
93gsrcoupe
Mar 14, 2005 08:31 PM
