Greddy turbo kit is it worth it???
Old Mar 4, 2005 | 03:24 PM
Del_Sol_s's Avatar
Default Greddy turbo kit is it worth it???
Used Greddy 15g turbo kit, Greddy Type 31 Intercooler kit and HKS SSQ BOV with the flange already welded on pipe.
$1100
also what are the numbers i can expect from putting this kit on? what are the gains it should provide..
Old Mar 4, 2005 | 03:27 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Greddy turbo kit is it worth it??? (jdmvic)
So it's the complete kit? What engine is this going on?
Old Mar 4, 2005 | 03:29 PM
xxscaxx's Avatar
Default Re: Greddy turbo kit is it worth it??? (litterbox)
id assume a d series b/c of the turbo size
the numbers all depend on how much boost you are pushing and your fuel setup (and obviously any engine work)
Old Mar 4, 2005 | 03:31 PM
Del_Sol_s's Avatar
its going on a d16y8 and yes it is a complete kit used for about 7k and not boosted over 8 psi.
Old Mar 4, 2005 | 03:59 PM
b18vtek's Avatar
why is he selling it?? depends on why he is selling it, you should get it if he need the money. GL
Old Mar 4, 2005 | 05:22 PM
Del_Sol_s's Avatar
he bought an s2000 so i think hes parting out his civic. Thats not a good reason to buy a turbo kit..(if seller needs money) but is the price hes asking a good deal?
Old Mar 4, 2005 | 05:30 PM
b18vtek's Avatar
Default Re: (jdmvic)
Try to get it for 950 and get it inspected if you cant do it.
Old Mar 5, 2005 | 06:11 AM
SLIPSTICK TIPPIN's Avatar
not worth it - my buddy sold his for 800 with a trust intercooler and piping
Old Mar 5, 2005 | 08:21 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvic &raquo;</TD></TR><TR><TD CLASS="quote">Used Greddy 15g turbo kit, Greddy Type 31 Intercooler kit and HKS SSQ BOV with the flange already welded on pipe.
$1100
also what are the numbers i can expect from putting this kit on? what are the gains it should provide..</TD></TR></TABLE>
$1100 is slightly high. Around $900-1000 would be a little more reasonable, although I did get around $1200 when I sold my kit. As for gains? Well, figure 5psi will net you around 170hp approximately. I ran the Z6 kit on my Y8 with the hack setup and was dyno tuned at 7psi. However, the HKS MBC I was using was ******* leaking and sticking, so I was only able to put down 179 flywheel hp and 175 lb-ft of torque. Not horrible, but the damn boost controller was broken to hell. HKS said it was perfectly fine, though, when my shop sent it to them for inspection.
Old Mar 5, 2005 | 08:24 AM
Hybrid96EK's Avatar
Default Re: Greddy turbo kit is it worth it??? (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">
$1100 is slightly high. Around $900-1000 would be a little more reasonable, although I did get around $1200 when I sold my kit. As for gains? Well, figure 5psi will net you around 170hp approximately. I ran the Z6 kit on my Y8 with the hack setup and was dyno tuned at 7psi. However, the HKS MBC I was using was ******* leaking and sticking, so I was only able to put down 179 flywheel hp and 175 lb-ft of torque. Not horrible, but the damn boost controller was broken to hell. HKS said it was perfectly fine, though, when my shop sent it to them for inspection. </TD></TR></TABLE>
You put down 179 FLYWHEEL horsepower? If so, that sucks.
Old Mar 5, 2005 | 08:26 AM
Daniel's Avatar
Default Re: Greddy turbo kit is it worth it??? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
You put down 179 FLYWHEEL horsepower? If so, that sucks.</TD></TR></TABLE>
Yeah, the boost controller was acting up pretty badly. The day I was dynoed, I made a thread in the FI forum to complain about my numbers.
bara6075
Nov 23, 2007 10:22 AM
Nicks95GSR
Oct 15, 2007 09:17 PM
ghostrider dc2
Feb 19, 2005 08:52 AM
TheHater
Jul 2, 2002 06:02 AM
zexdrex
Apr 14, 2002 09:01 PM
