Clutch Catches in different place all of a sudden??????
Old Mar 4, 2005 | 02:58 PM
hondaless's Avatar
Default Clutch Catches in different place all of a sudden??????
Ok exhaust broke at the resonator yesterday fixed it this morning and when i moved the car the clutch catches way at the bottom now. It used to catch in the middle. What can be the problem????
It's a 93 Civic EX.....is there a fluid resivior it's dark out now and can't seem to find one?
Is there an adjustment on the clutch anywhere I know there was on my CRX's cause it was cable and i don't know to much about hydralic.
Old Mar 4, 2005 | 03:16 PM
eK9aT10pSi's Avatar
Default Re: Clutch Catches in different place all of a sudden?????? (hondaless)
with hydrolic, you can bleed it at the slave cylinder
Old Mar 4, 2005 | 03:19 PM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaless &raquo;</TD></TR><TR><TD CLASS="quote">
It's the smaller reservoir to the right of the brake fluid resevoir.
Old Mar 4, 2005 | 03:30 PM
hondaless's Avatar
Default Re: Clutch Catches in different place all of a sudden?????? (Screwtape.)
Ok i looked at it and it said brake fluid on the top of the little one.......so i thought it was the slave cylinder to the brakes. Ill go bleed it tommrow and see what happens. Thanks for the replies.
ray.riddler92
May 4, 2011 01:00 PM
m3 boostin
May 30, 2007 01:20 PM
supamanRicer
Dec 5, 2006 02:19 PM
Prelude4ws
Nov 28, 2006 06:19 AM
tytyguy
Dec 3, 2005 02:32 AM
