transmission grinding
Old Mar 4, 2005 | 11:41 AM
JSPECCRX's Avatar
Default transmission grinding
ok i got a b16 with a ls tranny with gsr gears and a welded differental. it shifts smoothly a low rpm but when i get on it the gears dont grind it's almost like a clicking sound????? can anyone help me out
Old Mar 4, 2005 | 12:46 PM
crexhf17's Avatar
Default Re: transmission grinding (JSPECCRX)
u might have a bad cincro (if that is how u spell it) u could try and change ur tranny fluid and gear lube
Old Mar 4, 2005 | 01:22 PM
kjcarlos's Avatar
I had the same prob with my ys1 and i used gm synchromesh.......2 weeks later...no grinds at all!! give it a shake it works well
Old Mar 4, 2005 | 02:25 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (kjcarlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kjcarlos &raquo;</TD></TR><TR><TD CLASS="quote">I had the same prob with my ys1 and i used gm synchromesh.......2 weeks later...no grinds at all!! give it a shake it works well</TD></TR></TABLE>
Old Mar 7, 2005 | 05:57 AM
JSPECCRX's Avatar
Default Re: (LSVTEC 91 Civic)
what exactly is gm synchromesh...also i am using motor oil in my cable tranny should i change it to tranny fluid
Old Mar 7, 2005 | 06:33 AM
GreenBean's Avatar
Default Re: (JSPECCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECCRX &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is gm synchromesh...also i am using motor oil in my cable tranny should i change it to tranny fluid</TD></TR></TABLE>
When you say tranny fluid that mean auto trans fluid.
Tranny fluid is usually refereed as auto-tranny fluid. Now Honda MTF is very good.
A lot of dealers use 5w-30 motor oil in theirs for regular services, They however have to use Honda MTF if a warranty repair is made on a transmission. Go figure.
Although some have tried and like GM, General MOtors Synchromesh fluid.
miamiboy91
32
Nov 14, 2008 03:18 PM
hammergunner
Sep 11, 2008 08:00 PM
bertsb18hatch
Apr 6, 2008 09:45 AM
LorenGeist
Aug 14, 2004 12:05 PM
WONG FRIED RICE
Nov 20, 2003 07:41 PM
