PROBLEMS WITH STOP LIGHTS
hey guys, my tailight are mest up... MY BULBS ARE FINE, theyre brand new, its just the STOP LIGHT DOESNT COME ON WHENEVER I PRESS ON MY BRAKES... I PUT IT IN RIGHT, double checked... WATS GOING ON.. wiring maybe??
EDIT: MAYBE FUSE... ??
Turn your ******* caps lock OFF.
English is key.
When you apply pressure to your brake pedal your rear taillights don't work, correct?
If not make sure you've put the bulbs in right, check all fuses, check to see if theres a short,etc.
English is key.
I bet thats the problem. Could be wrong though.
