crank bearings.
Old Mar 4, 2005 | 11:03 AM
limpy's Avatar
Default crank bearings.
why are there crank bearings and not cam bearings... i know it is kind of a dumb question but i was just curious as to why. if you must be an *** and flame then go ahead , but to those of you that give an answer thanks.
Old Mar 4, 2005 | 03:39 PM
limpy's Avatar
Default Re: crank bearings. (limpy)
uhh yeah thanks for the help guys.... cmon someone has to know.
Old Mar 4, 2005 | 05:32 PM
NJIN BUILDR's Avatar
Ok...Ok
First the camshafts turn at half the speed of the crank.The only load is the valve spring pressure and the and the inertia of the valves,retainers,springs and rockers.This is nothing compared to the load on the crank and rods.The aluminum is a good bearing surface as long as the oil flow is adequate.The load is only in one direction unlike the crankshaft.There are very light thrust loads unlike the crank.
Those are some of the major reasons.
Glenn
Old Mar 4, 2005 | 07:01 PM
limpy's Avatar
Default Re: crank bearings. (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Ok...Ok
Glenn</TD></TR></TABLE>
thank you that is exactally what i was looking for, so when changing out the cams there is some scaring/scratches on the cam journals, does that need to be machined? Is there a way to fix the scaring/scratches?
Old Mar 5, 2005 | 04:10 AM
The cam bores can be align honed just like the main line.Unless its really severe I wouldn't do anything about it.As long as the cam turns freely your all set.
Glenn
Old Mar 5, 2005 | 12:35 PM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The cam bores can be align honed just like the main line.Unless its really severe I wouldn't do anything about it.As long as the cam turns freely your all set.
thanks man... you kick ***
Old Mar 6, 2005 | 12:44 PM
biotech0123's Avatar
good question by the way I was wondering the same thing
gdrum
Apr 6, 2017 06:57 AM
ShortbusEK
Mar 7, 2008 01:29 PM
hondaeg8
May 1, 2005 12:15 AM
NetLogic
Dec 16, 2004 01:57 PM
JustLooking
Nov 25, 2003 09:40 PM
