Timing belt
Old Mar 4, 2005 | 08:49 AM
JaHnAbOi's Avatar
Default Timing belt
Hey guyz, I have an situation for you that I think you guyz can help me with that i can't quite figure out. My water pump broke down and so I changed it. Well while I was unbolting the crank pulley on the block (the hard son of a bitch) i guess the placement of tdc was off. And when I got the new water pump in and the timing belt on my car ran fine for one day. The next day I decided to fix my timing with my timing light... now here's the tricky part. As I retarted it and advanced it to see where i was at, my car started choking itself every damn time I hit the gas... why is that? And even when i put the timing right where it should be it still chokes... Is it because I didn't set it at tdc before I put the belt? Or should it self ajust itself? Should I line up the crank pulley tdc with the cam gear? Iono! Help!!!
Old Mar 4, 2005 | 08:53 AM
GreenBean's Avatar
Default Re: Timing belt (JaHnAbOi)
If you didn't set it at TDC then you are wasting your time until then
Sorry for the bad news, but you may need to remove it again to check TDC.
Old Mar 4, 2005 | 09:06 AM
thatbluecrx's Avatar
Default Re: Timing belt (GreenBean)
doh
Old Mar 4, 2005 | 09:08 AM
EJ2-Fluffy's Avatar
Default Re: Timing belt (thatbluecrx)
Lol ur gonna have to have ur #1 Cylinder at TDC if you want to fix that =\
Old Mar 4, 2005 | 09:34 AM
JaHnAbOi's Avatar
Default Re: Timing belt (CRX-Fluffy)
Okai so that's all right? Anyone have a step by step picture thing I can follow? I mean, cuz I don't quite know how to picture it when I do it... Any steps you guyz can help with?!
Old Mar 4, 2005 | 12:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://www.cadvision.com/blanc....html
http://www.hondatuningmagazine...iming/
Old Mar 4, 2005 | 01:08 PM
JaHnAbOi's Avatar
Default Re: Timing belt (88DXCRX)
I pretty much did what you referred me to... but now my car won't start at all.... I placed the crank sprocket and camshaft sprocket to tdc... I put everything back the way i was suppose to and now the car doesn't want to start.... no ecu codes either... just doesn't want to start? Anyone know why? Help me!!!
Old Mar 4, 2005 | 02:10 PM
EJ2-Fluffy's Avatar
is your battery connected?!
Old Mar 4, 2005 | 02:20 PM
JaHnAbOi's Avatar
uh... duh! =P It cranks but doesn't start up...
Old Mar 4, 2005 | 02:39 PM
88cerx's Avatar
what about the dohc motor any one have step buy step pics and info on that every motor i see one of the cam gears arent strait up and down and i always forget
Old Mar 4, 2005 | 11:13 PM
JaHnAbOi's Avatar
Default Re: Timing belt (88cerx)
NVM Guyz! I did it the old way... just plug and play.... move and play.... plug and play till i 4 hours later I got it! Hahaha. Oh well thanks for the help. Btw i tried it tdc and what not... still didn't want to start. thanks anyways!
Old Mar 5, 2005 | 06:03 AM
EJ2-Fluffy's Avatar
Old Mar 5, 2005 | 06:16 AM
efcivic757's Avatar
once you get your motor set to TDC, also make sure your distributor is set on #1.
Old Mar 5, 2005 | 05:30 PM
88cerx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">what about the dohc motor any one have step buy step pics and info on that every motor i see one of the cam gears arent strait up and down and i always forget </TD></TR></TABLE>anyone have a link to pics for the dohc
Old Mar 5, 2005 | 05:38 PM
88DXCRX's Avatar
http://www.c-speedracing.com/howto.php
there is one for a b18c here...
Old Mar 5, 2005 | 09:05 PM
88cerx's Avatar
Evan Cronin
Aug 1, 2015 04:29 PM
volcomstoned805
Jun 7, 2009 09:31 PM
fatpride111
10
Nov 20, 2008 07:05 AM
gas saver 08
Jun 30, 2008 04:48 PM
maxspeed96ct
Mar 1, 2008 09:21 AM
