mini me idling to high !!!!
Old Mar 4, 2005 | 08:14 AM
darkstar90's Avatar
Default mini me idling to high !!!!
Ok.... I have all the vacuum lines and stuff hooked up right but it is idling at about 2500.....to me it sounds like a vacuum leak or the butterfly isnt shut all the way. I've checked both of these and neither seem to be the culpret.... Any suggestions would be greatly appreciated
Thanks,
Chris Bevenue
Old Mar 4, 2005 | 04:43 PM
LShatchie's Avatar
Default Re: mini me idling to high !!!! (darkstar90)
just try pulling on the butterfly to make sure its all the way closed, have u tried turning the idle down with the idle screw? also does the idle stay high even when fully warmed up ?
Old Apr 25, 2007 | 08:26 PM
MelloYelloCRX's Avatar
Default Re: mini me idling to high !!!! (LShatchie)
has ame prob, but mines idles at 3k no matter what temp....
Old Apr 25, 2007 | 08:37 PM
integrawow's Avatar
Not sure, but do ya'll have an FATV on ya'lls motors? FATV stands for fast idle thermo valve.
You may also want to get it checked for vacuum leaks via a smoke machine.
Old Apr 25, 2007 | 08:46 PM
89efDUSTY's Avatar
Default Re: (integrawow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">Not sure, but do ya'll have an FATV on ya'lls motors? FATV stands for fast idle thermo valve.
You may also want to get it checked for vacuum leaks via a smoke machine.</TD></TR></TABLE>
FITV , but yah clean you IACV or EACV, should be IACV but truthfully no real difference. Is your map on the TB or is it connected to the stock one via vacuum line to IM, if so i think that has to be changed. Check the idle adjustment screw, also in the TB if the Butterfly valve is closed all the way you will see a hole facing by the IACV "can see when you take off the intake arm" if you cover that when you put your finger on it. If it has suction that means you have a vacuum leak...Spray brake cleaner or carb choke all over your IM and TB (don't worry it doesn't hurt it), and if there is a vacuum leak, the idle will drop. Use that method then just plug it up. Also is your TPS hooked up right? Also see maybe your accelerator cable is too tight...Damn thats about it
Old Apr 26, 2007 | 10:57 PM
Efbluevtec's Avatar
check air flow screw on top of the throttle body. turn clockwise to turn it close. sometimes when its to loose. it will open while your driving.
Zee.I
Jul 11, 2021 11:36 PM
G. Man
Classic Hondas
Jun 25, 2011 07:48 PM
Pure Sol
16
Dec 31, 2007 12:06 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
ILOVEGIRLS
Mar 31, 2004 12:58 PM
