anyone ever put on lower tie bars??
Old Jan 21, 2002 | 04:57 PM
97accordex's Avatar
Default anyone ever put on lower tie bars??
I just got a lower tie bar (rear) for my 97 accord. Will probably put it in this weekend,,,,,,,,,, does anyone have any install tips???
Also got the front strut tower tie bar,,,,,,,, that looks pretty straight forward,,,, but I would like to get some new self locking nuts for the shock bolts. Does anyone know where to get these? The old ones are getting pretty corroded. Suppose I could wire brush/dremel them and clean them up though.
In general I would like to find a good source for hardware like nuts an bolts etc. Napa somethimes has them but not always. Usually I have to clean up the old ones.
Old Jan 21, 2002 | 07:57 PM
MestizoRacer310's Avatar
Default Re: anyone ever put on lower tie bars?? (97accordex)
I had something similar happen. The 3 bolts that attach the front mount to the engine block were missing. I went to my local hardware store and I got the coarsest thread pitch they had, but to no avail they didn't fit. Dealer only. You might be stuck in just getting new nuts from the dealer. The thread pitch might be "special" or "dealer only". Just something you might want to keep in mind.
Just in case.....thread pitch is the number of threads per inch. The more there are it's considered "fine" and less are called "coarse". Good luck on the install, I'm looking for used bars myself. ISO both rear upper and lower.
KGB_JDM
Feb 11, 2010 06:54 AM
CRX EF 88
12
Feb 20, 2008 05:54 AM
Froznface
14
Jan 25, 2006 05:49 AM
civiccrazy93
Dec 28, 2004 09:43 PM
