Installing Honda Civic Lower Tie Bars
Ok, I did a search and nothing really answered the question I have. Plus, my directions look like someone had a spare 3 minutes and a copy of Microsoft WordPad. On top of that my LCA bolts are a bitch. Only an impact will break them loose and that's just the bolt...the nuts are still rusted to the frame. Pain in my ***.
How the hell do I mount a Megan lower tie bar? I get the basics: jack it up (and all the safety precauts that go w/ that), loosen the LCA bolts, put the brackets on the bolts, and tighten everything up. But what side of the frame are these things supposed to go on? Do they mount on the nut side (toward the front), or the head of the bolt side (rear)? I don't wanna mess w/ my rusted stuff til I figure this out. Any help would be great. Plus, a single pic of an installed LTB would be an awesome addition to the info. Thanks in advance.
Re: Installing Honda Civic Lower Tie Bars (Froznface)
take out the lca bolts, put lower tie bar on and tighten up bolts. The tie bar faces the rear bumper. You can see it under the rear of the car
As long as I dont have to take out any more Metal Gears
Re: (MARSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARSH »</TD></TR><TR><TD CLASS="quote">be sure to use a lot of lube on the LCA bolts as well.
i've heard so many horror stories about rusted LCA bolts stripping and what not.</TD></TR></TABLE>
Ya since u live out there, u could encounter a rust problem. Let it soak really good.
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">Those nutz arent rusted on.. they are welded so stop cranking on them!!!
Atleast my eh3 was welded.</TD></TR></TABLE>
what?
what?
Re: (Sleepy_Red_hatch)
ya arn't all of the nuts on the lca's welded on? throw some heat on them bolts, they'll come off, and then anti-seize on the thread when you re-install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
what?</TD></TR></TABLE>
The nut on the backside of the rear lower subframe isnt jsut rusted shut to it. It is welded to it. Its not welded to the LCA and nothing is welded to the LCA.
Where the bolt threads into, If your underneath the car with 2 wrenches, you dont need to be. Get what im getting at???
Re: Installing Honda Civic Lower Tie Bars (-Gambit-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- »</TD></TR><TR><TD CLASS="quote">take out the lca bolts, put lower tie bar on and tighten up bolts. The tie bar faces the rear bumper. You can see it under the rear of the car
Thanks Gambit, thats the info I needed. Nice pic of a very clean hatch!
Re: Installing Honda Civic Lower Tie Bars (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">is it just me? or did that sound simple?</TD></TR></TABLE>
Believe me, if it was simple it would be done already and I wouldn't be adding to my carpal tunnel by posting here. If you saw the underside of my car (covered with something resembling rhino liner or line-x) you'd understand.
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">Those nutz arent rusted on.. they are welded so stop cranking on them!!! Atleast my eh3 was welded.</TD></TR></TABLE>
Ok, that makes sense now. That would explain the difference in their size too. Hard to tell whats going on under my car. I had a bitch of a time with the exhaust bolts so I just figured these were the same. Nice to know, thanks!
Re: (dohcdelsol)
Where the bolt threads into, If your underneath the car with 2 wrenches, you dont need to be. Get what im getting at???</TD></TR></TABLE>
I get what you're getting at. Much thanks.
Re: (Froznface)
Thanks guys. This has really helped me out. I'll post up some pics when its done, which should be soon, weather permitting.
SD_EM1
06-10-2004 11:28 PM
