What RPM in 4th gear... 135-155 mph cars
Old Mar 4, 2005 | 06:08 AM
g2turbo's Avatar
Default What RPM in 4th gear... 135-155 mph cars
For all the cars that are trapping 135-155 mph what rpm are you crossing the line and are you remaining in 4th gear through the finish. I know that the B16 tranny and GSR tranny will be different, and also tire size will also effect this. Please post your results. I think most of the SFWD/Turbo 4 cars are running a 25" tire.
For the cars that rev 4th out to 9500-10k are you only going that high in 4th gear or do you rev 2nd and 3rd that high as well.
Old Mar 4, 2005 | 06:23 AM
DaveF's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (g2turbo)
you want to be @ your peak power or a bit after while going through the traps(in 4th).
you can check out this gear speed calculator to aide you in what trans/final drive/ tire size you want to go with.
-dave
Old Mar 4, 2005 | 06:52 AM
tommyten's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote"> you want to be @ your peak power or a bit after while going through the traps(in 4th).
-dave</TD></TR></TABLE>
thanks man, thats **** is awsome
Old Mar 4, 2005 | 06:54 AM
tommyten's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (jerseykid609)
I was at the top of 4th when I trapped 141 (almost redline)
Old Mar 4, 2005 | 07:12 AM
g2turbo's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (Tommy Ten)
so you guys are taking every gear that high? Are you guys also running stock oil pumps?
Old Mar 4, 2005 | 07:14 AM
tommyten's Avatar
yeah, stock pump
Old Mar 4, 2005 | 01:58 PM
JL's Avatar
JL
that calculator is so cool.
Old Mar 4, 2005 | 03:54 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">so you guys are taking every gear that high? Are you guys also running stock oil pumps?</TD></TR></TABLE>
make sure ya get your rotating assm. balanced. and use a good crank pulley.(fluidampener)
Old Mar 4, 2005 | 05:50 PM
Blown90hatcH's Avatar
Fluidampr and stock pump here. Trapping 141 with a 26" tire around 8900 in 4th ITR tranny.
Old Mar 5, 2005 | 07:31 AM
g2turbo's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (Blown90hatcH)
thanks for the replies. I have my crank balanced and am definitely running a fluidampr
Old Mar 5, 2005 | 03:46 PM
civicguy's Avatar
so for how much the fluiddampr goes for? and where to get one?
Old Mar 5, 2005 | 04:59 PM
DaveF's Avatar
Default Re: What RPM in 4th gear... 135-155 mph cars (civicguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy &raquo;</TD></TR><TR><TD CLASS="quote">so for how much the fluiddampr goes for? and where to get one?</TD></TR></TABLE>
arturo sells the fluidampner i believe.
Z10 sells the Ati super damnpener
Old Mar 5, 2005 | 06:08 PM
Arturbo on here sells the fluidampr.
Old Mar 5, 2005 | 06:36 PM
Tyler H's Avatar
My JDM H22 tranny (M2B4) and 25" slicks would put me at 8300 rpm @ 135 and 9550 rpm @ 155. Best I've trapped so far is 143 mph. I take it to 9000 in every gear. Stock oil pump, stock crank pulley with accessory drive cut off (alt only).
Tyler
MoiMotorsports
Aug 3, 2010 04:46 PM
catfishracer4748
Feb 27, 2010 10:20 AM
Si-ONARA
Nov 19, 2008 07:20 PM
Deathwish
19
May 27, 2005 03:41 AM
Driven
12
Oct 19, 2004 06:24 PM
