H22 with no VTEC?? Need Help
Some dude is trying to sell me a H22. He said that it is missing one cam shaft and the engine is from japan. He said that that engine has no VTEC.
Is there an H22 without VTEC? or was he pulling my leg.
Thanks
Thanks
VTEC is not a crossover from cam1 to cam2. Its a change in the cams aggressiveness using different profiles. The motor will not run withough one camshaft either. If he is telling you there is no VTEC on an H22, Im thinking you either are not getting an H22 or the H22 you are getting is busted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by window44 »</TD></TR><TR><TD CLASS="quote">Some dude is trying to sell me a H22. He said that it is missing one cam shaft and the engine is from japan. He said that that engine has no VTEC.
Thanks </TD></TR></TABLE>
No there is no h22 with no vtec. But vtec won't work with only one camshaft. Thats what vtec is, its the crossover from camshaft1 to 2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 »</TD></TR><TR><TD CLASS="quote">But vtec won't work with only one camshaft. .</TD></TR></TABLE> I dont think the engine will run on one cam either.
YEP - I think he's trying to stiff you. I mean - look at it first to make sure it says H22 on it.... Check the mileage....and check the price with us...if it's a resonable price - (CHEAP!!!), then you should buy it...since you're going to build it anyway right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 »</TD></TR><TR><TD CLASS="quote">even if its cheap dont buy it this seller's a ******* toole
Agreed, buy your motor from someone you trust or a respected seller like HMO
</TD></TR></TABLE>Agreed, buy your motor from someone you trust or a respected seller like HMO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
Agreed, buy your motor from someone you trust or a respected seller like HMO</TD></TR></TABLE>
yeah i second that, stay away from this! , guy sounds retarted
forget about this *******
