will a GSR intake mani fit a b16
Old Mar 4, 2005 | 02:01 AM
G60's Avatar
G60
Default will a GSR intake mani fit a b16
Dunno if I should put this in here or not, but will the intake manifold from a GSR fit on an obd0 b16? Would the dual-length runners give that much of a difference?
Old Mar 4, 2005 | 02:05 AM
KFBhonda's Avatar
Default Re: will a GSR intake mani fit a b16 (G60)
won't bolt up.
different bolt patterns.
Old Mar 4, 2005 | 02:06 AM
G60's Avatar
G60
Default Re: will a GSR intake mani fit a b16 (KFBhonda)
cool thanks
efcivic01's Avatar
It will not fit. Type-R will fit and will help alot.
Old Mar 4, 2005 | 02:08 AM
dr_latino999's Avatar
Default Re: will a GSR intake mani fit a b16 (efcivic01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efcivic01 &raquo;</TD></TR><TR><TD CLASS="quote">It will not fit. Type-R will fit and will help alot. </TD></TR></TABLE>
A lot is a relative term, everyone's opinion is different; I.E. power in the low end a lot, power everywhere a lot, or power in the top?
Old Mar 4, 2005 | 06:36 AM
G60's Avatar
G60
What are the specific advantages to the type R manifold? Anything above better flow? Any dyno sheets?
Old Mar 4, 2005 | 07:38 AM
TIRENECK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G60 &raquo;</TD></TR><TR><TD CLASS="quote">What are the specific advantages to the type R manifold? Anything above better flow? Any dyno sheets?</TD></TR></TABLE>
gotta flow good cause skunk2 and blox are the same ****.
Old Mar 4, 2005 | 11:18 AM
KFBhonda's Avatar
type-r has short, fat runners, which are great for higher rpms. but, you sacrifice a bit in the lower and middle rpms. these are hondas we are talking about, so most people go for the top end of the spectrum.
Old Mar 4, 2005 | 01:29 PM
kjcarlos's Avatar
The 94-95 gsr i.m. does fit the b16!!
Old Mar 4, 2005 | 03:17 PM
ryanbartholomew85's Avatar
Default Re: (kjcarlos)
it may bolt up, but the coolant passages to not match. therefor it does NOT work
tempsohc
15
Jul 14, 2011 06:08 PM
jdmdikk
24
Nov 28, 2008 09:01 AM
Honda owner
Jan 6, 2006 02:29 PM
mrbsponge
Apr 30, 2005 04:29 PM
RaVeN
Oct 10, 2002 10:49 AM
