b18c1 in 89 ef hatch
Old Mar 3, 2005 | 09:36 PM
StraightCivic's Avatar
Default b18c1 in 89 ef hatch
Im now looking around on the internet on hmotorsonline for b18c1 motors. On jpec they say i need b series tranny, b series motor mounts and obd1 conversion. My car is also efi ( dpfi ). What all do i need to put this b18c1 motor in? I know i need a fuel injector resister box but what else do i need? And also where can I find these parts at a cheap price?
Thanks
and can someone show me a link of dpfi to mpfi?
Old Mar 3, 2005 | 09:52 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: b18c1 in 89 ef hatch (StraightCivic)
http://www.rywire.com/ for wiring.. cheapest and best.
youll need the dual to multipoint conversion and the obd1 conversion and vtec harness. and some motormounts at http://www.hasport.com or other places. do a search and dont forget to check "search body". that should atleast get you started.
Old Mar 3, 2005 | 11:00 PM
eda6's Avatar
Default Re: b18c1 in 89 ef hatch (sanimalp)
If you'll be using the gsr injectors don't buy a resistor box. The resistor box's job is to create a voltage drop for p&h injectors. The saturated gsr injectors need 12V.
Your motor should come with dizzy and ecu. You'll need an obd conversion harness and a 4 wire o2 sensor.
Old Mar 6, 2005 | 06:24 PM
Default Re: b18c1 in 89 ef hatch (eda6)
so your saying i dont need to convert to mpfi just that motor will work or what do u mean?
Old Mar 6, 2005 | 07:16 PM
doublethink's Avatar
you have to do a mpfi frist, then use the odb1 conversion harness.
or another route, send out the whole engine harness to hasport or one of the guys on here, and then youll only have to make a few adjustments at the ecu clips, if you think itd be too hard.
basically the obd0-obd1 conversion harness is going to assume and hf or si wiring. so you need to make your car match that, or have it done for you.
get it?
Old Mar 6, 2005 | 09:01 PM
Default Re: b18c1 in 89 ef hatch (doublethink)
so i just need to modify the harness? lol im totally lost im dumb with this **** u need to speak retard language
Old Mar 6, 2005 | 09:14 PM
NikoZai's Avatar
First you convert to MPFI, then instead of the Injector Resistor box you use a injector block off plug like this:
You then need to remove a few plugs from your harness, add wires for crank angle sensor at your distributor, more wires and plugs extended around your I/M And i'm being vauge because your best bet is to leave it to the professionals.
Old Mar 6, 2005 | 09:42 PM
Exempt's Avatar
Default Re: b18c1 in 89 ef hatch (NikoZai)
Great write up on it here...
http://www.norcalcrx.org/library/b18cswap.shtml
skill178
15
Jul 16, 2012 08:40 AM
dem0nk1d
Jun 20, 2007 04:44 PM
95civicB16
May 1, 2007 02:04 PM
nucivowner
Mar 11, 2005 11:33 AM
lephem
Apr 28, 2004 07:14 AM
