Bearing Color Code
I know that alot of people are using any bearings. (Green is mostlt the common color) Is it a good idea just to go ahead and get all green colored bearings?
There are like 20 peices am I correct?
that would be stupid.
read teh block and the crank, adn buy the corrosponding bearings.
then plastigauge
if clearances are ok, run them. if not, adjust by buying a differant bearing of larger/smaller thickness
then plastigauge
just platigage the crank to check for clearance's. here's a good write up:
http://b20vtec.com/forums/showthread.php?t=4620
When people buy aftermarket bearings like ACL, they typically have their crank spun (slightly milled) at a machine shop to fit their bearings. Where as with OEM you can order the bearings to fit the crank/block.......
This is also an EXCELLENT write-up that covers building the whole bottom end of a B18C (including bearing sizing/installing): http://www.evans-tuning.com/vi...build
Modified by 1stGENGSR at 12:02 AM 3/7/2005
thnx for the info in here :D this topic has helped me allot,
the link to the write up from boosted hybrid helped me allot becaus its well written and i trust him a full 100 % as it comes to Honda tuning and building.
totalimpact
Nov 16, 2005 12:01 PM
