carbon buildup on piston dome, can it be removed?
Old Mar 3, 2005 | 04:45 PM
raider099's Avatar
Default carbon buildup on piston dome, can it be removed?
i have my head off of my block and i noticed that there is normal carbon buildup ontop of the pistons, i was wondering if i can go ahead and remove that carbon before the head goes back on. I have heard it messes up something, i cant remeber what some people were saying. anyone have any imput?
Old Mar 3, 2005 | 05:42 PM
SpeedDreamz.com's Avatar
Default Re: carbon buildup on piston dome, can it be removed? (raider099)
I light mist of water into the intake while the car is running will remove carbon buildup.
Old Mar 3, 2005 | 06:48 PM
Chris22215's Avatar
Default Re: carbon buildup on piston dome, can it be removed? (SpeedDreamz.com)
I did not know that.
Old Mar 3, 2005 | 07:15 PM
94DOHCGsr's Avatar
Default Re: carbon buildup on piston dome, can it be removed? (Chris22215)
If you can fit a wire wheel into their, you could scrape off most of it. But when u put it back together, water or seafoam will do the job also.
Old Mar 3, 2005 | 07:27 PM
mmuller's Avatar
Mad Scientist
Default Re: carbon buildup on piston dome, can it be removed? (94DOHCGsr)
do not scrape any of it with a wire wheel or anyhting of that kind.. crap is going to get between the piston and cyl. and your going ot do more damage than good.
as sayd above, best way is with water.
Old Mar 3, 2005 | 07:32 PM
Kendall's Avatar
I've never tried the water idea, but Seafoam is particularly good at removing the carbon.
Old Mar 3, 2005 | 08:04 PM
neogenesis2004's Avatar
Default Re: (Kendall)
i've personally done both and recommend using water then seafoam. If you use seafoam on a high mileage engine you might break off too much carbon at once and actually ruin something. I have personally ruined valve seals in 2 engines doing this. Water "steam cleans" your engine more or less and is much more gentle. So I recommend one before the other. But then again....who cares what i think...
Old Mar 5, 2005 | 08:13 AM
raider099's Avatar
interesting. i guess ill try the water effect once i put the engine back together
Old Mar 5, 2005 | 10:24 AM
Default Re: (raider099)
Remember just use a sprayer and mist it into the tb while the car is running and warm. JUST A MIST, NOT A SQUIRT!.
Old Mar 5, 2005 | 10:55 PM
PrettyLude's Avatar
the water method is like steam cleaning
Old Mar 6, 2005 | 09:52 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I've never tried the water idea, but Seafoam is particularly good at removing the carbon.</TD></TR></TABLE>
i drive a honda
Welding / Fabrication
12
Oct 29, 2008 03:44 PM
JDM_Acccord
Paint and Body
Jan 21, 2008 02:46 PM
civicshowracing65
May 29, 2005 04:59 AM
Bloodline
Sep 23, 2004 09:29 AM
slowcivic
Feb 27, 2004 07:23 AM
