Bought that 87 Accord, couple more questions
every loght you take out should have a number on them so you know what to get...i don't understand why you can't find the pcv valve on the car....it should be very noticeable....and for the gas i would drain it and put new in!!!!! 4 years is a long time.....
dude i can answer all your questions real fast.
first off the light bulbs, if you go to the auto parts store you can ask the sales dude if they have a reference for light bulbs. usually they do! and that will tell you which bulbs go where and which ones to buy. usually the bumber lens bulbs are a standard 1157. when i say standard i mean all the light bulb manufacturers use the same number. and the hose comin out of the valve cover or cam cover is the oil breather hose. on a 3rd generation accord there is only one hose comin out and thats the one. the pcv valve is under the intake manifold you cant see it unless you go lookin real hard for it . the two fuel filters are easy. i believe the primary fuel filter is under the hood bolted to the firewall. if your standing in front of the car looking at the engine its on the left side right next to a black box with vacuum lines comin out of it. there should be two hoses bolted to it. and the other one is back by the fuel tank im not real sure were exactly cause ive never looked for it. oh and one more real helpful hint that you will need, go to http://www.3geez.com there youll find tons of info about your car. belive me! be sure to use the search function first so you wont get yelled at for posting repeat threads! if anymore questions about your wheels drop me a line on that forum. my user name is buds302 ill help ya
Terabass
Aug 20, 2007 08:24 PM
ny153
Sep 13, 2006 04:00 AM
mushu315
Apr 27, 2005 07:45 PM
