crx door compatability
Old Mar 3, 2005 | 01:09 PM
GSRCRXsi's Avatar
Default crx door compatability
ok i need some new doors for my crx. and ive been looking and ive come across a few sets that might work. one set isnt confirmed to be 2nd gen doors yet, but im waiting on this. the only thing im iffy about is the year on the door. its possible that its a 88 with pillar mounted belts. will the door physically fit on the car? would it work if i swapped over my door panels and seatbelt assembly? any and all help is appreciated.
this is why i need new doors. and pictures help bring attention to my thread ive noticed
Old Mar 3, 2005 | 01:52 PM
dod's Avatar
dod
Default Re: crx door compatability (GSRCRXsi)
i think the doors will fit on the car if you take the upper latch out of the door jam (the thing that guides the door around where the seatbelt is), but i do not think that you can mount the belts into the 88 doors, but you could get the pillar mount seat belts, or a 5 point harness. the 88 doors look cleaner any way my .02, but you need seat belts. and if you went with the pillar mount belts, you would also have to replace the plastic that goes around the rear windows.
Old Mar 3, 2005 | 01:57 PM
kid-honda's Avatar
I would suggest a new door skin but if your dead set on replacing the whole door yes any 2gen door will "fit" its just going to require some work as stated above.
Old Mar 3, 2005 | 01:58 PM
Tyson's Avatar
i wish i bookmarked the thread that had pictures, but basically, what dod said is true, 88 doors will fit the 89+ chassis, but not the reverse. then the problem is seat belts. ive heard of ppl putting 88 pillar mounted belts on 89+ chassis, but it was not simple.
honestly, that door looks salvageable if you got a good body shop if you really had to. but if youre going to replace the door, unless you got a harness setup, 88 doors wont work for you.
Old Mar 3, 2005 | 02:01 PM
kid-honda's Avatar
Default Re: crx door compatability (Tyson)
Thats what I am saying a new OEM door skin will make the door look brand new.
Old Mar 3, 2005 | 02:03 PM
thatbluecrx's Avatar
the trims are different
(even tho it doesnt look like u want them)
Old Mar 3, 2005 | 02:08 PM
GSRCRXsi's Avatar
Default Re: crx door compatability (thatbluecrx)
i do want the trim, my car used to have a WW kit on it but was stolen, hence why there is no trim and the doors look like crap. and the reason i want new doors as opposed to getting new skins is because one that would cost more then new doors mostlikely, same deal with taking it to a body shop. it will cost way more to have it fixed.
Old Mar 3, 2005 | 03:48 PM
GSRCRXsi's Avatar
and someone else mentioned that the trim was different. can you use 89-91 trim on an 88 door?
Old Mar 3, 2005 | 06:48 PM
GSRCRXsi's Avatar
up
Old Mar 4, 2005 | 08:57 AM
GSRCRXsi's Avatar
bump
Old Mar 4, 2005 | 09:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">and someone else mentioned that the trim was different. can you use 89-91 trim on an 88 door?</TD></TR></TABLE>
I'm not sure...
I forget which way it is but..
the bump molding for doors hitting it is wider or thinner depending on the year.. BUT I'm pretty sure either molding will fit in either year, if you want to buy the moldings seperate
not sure about the bottom trim piece
Old Mar 4, 2005 | 09:07 AM
Outsane's Avatar
whats involved in replacing a door skin?
I have never done it before..
Old Mar 4, 2005 | 11:25 AM
ukdm crx's Avatar
Pillar mounted seatbelt doors will fit on all crx's. Door mounted seatbelt doors fit on pillar mounted seatbelt doors but you have to mod them a bit.
Old Mar 4, 2005 | 11:30 AM
GSRCRXsi's Avatar
Default Re: (ukdm crx)
can you put the seatbelts from a door mounted crx onto the doors of a crx thats has pilar mounted seatbelts if you use the 89-91 door panels??
joeyblow
Oct 2, 2005 02:41 PM
rhetorical
20
May 28, 2004 10:09 PM
B2FiNiTY
20
Dec 13, 2003 09:46 AM
turbo sol
Sep 15, 2003 02:13 AM
.ShawnD.
11
Nov 12, 2002 05:45 AM
