why is my car thumping?
Old Mar 3, 2005 | 12:32 PM
penney's Avatar
Default why is my car thumping?
well, i was driving today, and noticed a light thumping noise coming from the passenger side of my car. i had to travel a decent distance today dmv, dealers board, ect (just got my sales liscense!) anyways, throughout the day, i notice it getting louder and louder while braking...sometimes making the car dive to the left under medium to hard braking while on the interstate. on my way back home, it started a loud thumping even while coasting...it kinda sounded like a flat tire. got home and checked, no flat, and the brakes visually appeared to be fine. also, the p-side axle was replaced about 4k ago, so i doubt it is that.
has anyone ever experienced this...any ideas? thanks guys
Old Mar 3, 2005 | 02:00 PM
3.504's Avatar
Default Re: why is my car thumping? (97vtecGSR)
a thump like somethings hitting the bottom of your car? this is a wierd problem. is it fast enough to be like a vibration or is it slow, just a thump thump thump? i'd say go ahead and check the ball joints for the boot being busted, or any grease leaking around them, then i'd check the bushings to see if they are dry rotted. maybe your lug nuts came untightend. the axle would only be the problem if it did so under acceleration either in a strait line or turning (depending inside or outside joint). usually wheel bearings make a whiring noise, like swush swush swush, and increases with road speed. i've heard of wheel bearings clunking, but i've never seen one get that bad in person. but this could be your situation.
try to describe the simptoms a little more and get real specific on when it happens, under what conditions, and describe the actual noise itself
Old Mar 3, 2005 | 04:49 PM
vtecfed's Avatar
Default Re: why is my car thumping? (3.504)
i would also check the lug nuts.usually when you will notice the thumping problem decelerating.
Old Mar 3, 2005 | 06:53 PM
confucius's Avatar
Default Re: why is my car thumping? (vtecfed)
i remember hitting a pot hole once. and my steering wheel started to shake real bad.
even going really slow, the steering wheel slowly bounches left and right.
i check my wheels and saw nothing and had no idea what was wrong.
i drove on the freeway and the steering wheel was shaking really bad.
all of a sudden i herd a loud popping explosion noise and then my right fender liner ripped out. while my car jerked to the right really bad.
i kept driving and exited the freeway, drove to a lot and saw the my right tire thread ripped out and wrapped around he axle and ripped the cv boot and all the grease splatterd all over.
the fenderliner was gone and my fender was bent out of shape. my right side skirt was chipped really bad and needed to be repainted.
this was the worse thing i had even been through since i was rear ended.
Old Mar 3, 2005 | 10:09 PM
Slain's Avatar
is there any abnormal tire wear on that tire you checked ? a
Old Mar 5, 2005 | 11:23 AM
sleeper96's Avatar
Default Re: (Slain)
check your sway bar bushings.
Old Mar 5, 2005 | 11:26 AM
Atheist's Avatar
Thump would be bushings or cv
Old Mar 5, 2005 | 11:50 AM
kevin85193's Avatar
Default Re: (Atheist)
wow, wierd, i have the same exact problem.. I heard it last night, while breaking it would get louder and louder as i slowed down. I'm taking it to the mechanic monday, no more driving for me this weekend
Old Mar 5, 2005 | 01:51 PM
grocerygetter's Avatar
Default Re: (kevin85193)
my teg did that...when I got underneath it the sway bar had pulled out of the subframe...ouch.
Old Mar 5, 2005 | 03:05 PM
kevin85193's Avatar
Default Re: (grocerygetter)
well, i washed my car today(power washed the rims and inside of the wheelwell) and i took the car for a drive and the noise stopped... so i'm quite confused.
Old Mar 5, 2005 | 03:29 PM
playskool's Avatar
Default Re: (sleeper96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper96 &raquo;</TD></TR><TR><TD CLASS="quote">check your sway bar bushings.</TD></TR></TABLE>
def try looking into your sway bar bushings..those mounts that hold the bushing in are rather weak.sometimes it comes out one side.
i had the same THUMP happening while slowing down, going over minor imperfections on the road, speed bumps.. i changed out alot of suspension components and it ended up being a a stupid D bracket.
my lil asian eyes cant see like the round eyes.
accord_raffi
Jan 26, 2009 03:34 PM
PINKS
30
May 22, 2006 01:52 PM
PINKS
26
May 22, 2006 01:51 PM
Jimmii
Apr 8, 2005 03:54 PM
