Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
anyone using the G-force head and neck restraint?
Old Mar 3, 2005 | 12:17 PM
tom91ita's Avatar
Banned
Default anyone using the G-force head and neck restraint?
Has anyone used the g-force head and neck system. it is not as sophisticated as the HANS but still relies on the belts.
http://www.gforce.com/products/srs1/srs1.html
trying to come to grips with balancing cost vs. safety after driving for years with nothing but a foam neck brace.
planning to buy a high quality aluminum seat with side head supports.
tried searching for head and neck and g-force but only getting HANS equipment and debates of it vs. others.
Old Mar 3, 2005 | 12:20 PM
ryan12321's Avatar
Default Re: anyone using the G-force head and neck restraint? (tom91ita)
If you're in the market a friend of mine has his isaac device on ebay. starting at $400
http://cgi.ebay.com/ebaymotors...=WDVW
Old Mar 4, 2005 | 11:57 AM
tom91ita's Avatar
Banned
Default Re: anyone using the G-force head and neck restraint? (ryan12321)
i thought that the isaac was not acceptable for the scca as per this fasttrack. has there been any changes since then?
http://www.scca.org/_Filelibra...k.pdf
Old Mar 4, 2005 | 12:20 PM
Crack Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tom91ita &raquo;</TD></TR><TR><TD CLASS="quote">i thought that the isaac was not acceptable for the scca as per this fasttrack. has there been any changes since then?</TD></TR></TABLE>
No changes that I've seen. The Isaac currently does not meet GCR 20.4 (shoulder harnesses must be secured with a single release).
Old Mar 4, 2005 | 12:29 PM
hbennett76's Avatar
Default Re: anyone using the G-force head and neck restraint? (Crack Monkey)
I use it (although I haven't USED it) but then I also sell it. If I can answer any questions, fire away.
Howard Bennett
Racer Wholesale
Old Mar 4, 2005 | 07:23 PM
Dan GSR's Avatar
Default Re: anyone using the G-force head and neck restraint? (hbennett76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbennett76 &raquo;</TD></TR><TR><TD CLASS="quote">I use it
Howard Bennett
Racer Wholesale</TD></TR></TABLE>
can u give a mini review on it?
do u like it? hard to buckle in/out?
does it restrict side to side movement?
I have a Pro Force 1, and am considering getting one
Old Mar 7, 2005 | 06:47 AM
hbennett76's Avatar
Default Re: anyone using the G-force head and neck restraint? (Dan GSR)
I had to change the way I buckled into my harness. I now have helmet on before I try to strap in. I go by feel. I grab my shoulder straps one at time and "feel" each one over the bottom rod of the SRS-1 then snap into the cam-lock buckle. Not really hard to do, just different. It is definitely easier if you have someone to do it for you. If you are waiting in a staging line for a long period of time and want to take your helmet off, you have to unbuckle your harness. When getting out of the car, you just unbuckle your harness and the SRS-1 goes out with you.
It does restrict how far you can turn your head side-to-side but they all do. My experience is that the SRS-1 has more side-to-side movement. I like it pretty good, especially for the price.
Howard Bennett
Racer Wholesale
Old Mar 7, 2005 | 02:13 PM
asoduk's Avatar
we had a presentation on head and neck devices at the OH/IN NASA banquet this year. there was a write-up about it on the NASA website, but I can't seem to find it. the short of it though was that a GM race safety engineer was there to tell us about various safety devices currently in use, that should be making their way to our club racing cars. he had all sorts of video from the head and neck restraint device tests that they ran and explained how they worked. I'm not going to try to explain it, but he basically told us that if we are going to get something, get the hans. While the strap type devices do help, its not as much as the hans. After seeing the videos of it vs the strap type devices, I'd definately go with hans. If anyone has a link to that info on the nasa site, it would be a nice addition to this thread.
I'm no engineer, just trusting what the safety guy from GM said, and I think he's pretty credible as many of the top sanctioning bodies listen to him too.
EH-3
Jun 19, 2006 09:36 AM
VaporTrail
Oct 4, 2002 09:08 AM
