My timing belt is loose....
Old Jan 21, 2002 | 02:51 PM
3rdGteg's Avatar
Default My timing belt is loose....
Though the main problem is that my tensioner bolt is stripped. Somehow, I can't get the bolt loose at all. Even if I could, I heard I can't pull that bolt out all the way and change it unless I take the whole timing belt assembly off--> That sucks!
What's the easiest way to break the bolt loose and change it?
Old Jan 21, 2002 | 03:51 PM
mingchi96
Guest
Posts: n/a
Default Re: My timing belt is loose.... (3rdGteg)
try using a vise grip. Just be careful not to break the head of the bolt off leading the bolt still threaded... then u gotta take yr motor out and have a machine shop tkae it off
Old Jan 22, 2002 | 11:08 AM
3rdGteg's Avatar
Default Re: My timing belt is loose.... (mingchi96)
I really can't fit a vise grip/or any wrench around the bolt, since the lower timing belt cover is around it. Only a socket would fit, but it's stripped.
Old Jan 28, 2002 | 10:37 AM
3rdGteg's Avatar
Old Jan 28, 2002 | 02:54 PM
Web_Head's Avatar
New User
Tow it to the dealer
WaryDriver
27
Oct 7, 2015 08:42 PM
ke7joi
Classic Hondas
Jul 16, 2014 07:51 AM
MC Slide Hammer
Mar 23, 2011 02:25 PM
Bignel00
Jun 1, 2007 05:27 PM
b17gsr
Feb 11, 2003 07:46 PM
