Best throttle body size ??
Old Mar 3, 2005 | 09:15 AM
krystianitr's Avatar
Default Best throttle body size ??
Which Size Throttle body the best for my set up???:
JE 81.5 mm Pistons CR 12.5:1 b18c1 (CR--> 12.2-12.3 for itr)
Camshaft skunk 2 stage 2
RC Engineering Injectors 310cc
AEM cam gears
Skunk2 Valve Springs & Titanium Retainers Type R
-cam gears AEM
-AEBS Typhoon Intake Manifold
-AEM CAI
-B # M Fuel Pressure Regulator
-Headers DC sport and exhaust supersprint
Apexi VAFC II
Hondata s100
I think 68mm or 70mm ,which will be better
Old Mar 3, 2005 | 10:08 AM
baonest's Avatar
Default Re: Best throttle body size ?? (krystianitr)
no TB at all
Old Mar 4, 2005 | 06:32 PM
kidkombo's Avatar
Default Re: Best throttle body size ?? (baonest)
^^^ ITB'S!!!
Old Mar 11, 2005 | 12:46 PM
Default Re: Best throttle body size ?? (kidkombo)
If I would like change ITB I musted change RC enginering? and I need standalone??
But ITB it is too noisy
Old Mar 11, 2005 | 12:53 PM
ZygSpeed's Avatar
Your stock throttle isn't holding you back much, and if at all only 1-3 whp.
If you had an 84mm bore and more compression with some stage 3 type cams it would probably be a different story.
Oh ... and a RACE header instead of the comptech 4-1.
Old Mar 11, 2005 | 01:44 PM
Jowee's Avatar
Default Re: Best throttle body size ?? (zygspeed)
Answer---> 70mm
But then again, what do I know?
Old Mar 11, 2005 | 01:55 PM
Default Re: Best throttle body size ?? (ITR 98 1162)
which will be better sice for ITR for my set up and factory which is good spoon,BBK,,Erick,STR,RPM??spoon NO because 70mm outside and inside 64. I need 70mm and 68 inside
THX
Old Mar 11, 2005 | 02:03 PM
Bbasso's Avatar
You have other things to worry about before the TB, like a half *** exhaust setup.
Old Mar 11, 2005 | 02:12 PM
Default Re: Best throttle body size ?? (Bbasso)
I have complety exhaust
Old Mar 11, 2005 | 02:26 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr &raquo;</TD></TR><TR><TD CLASS="quote">I have complety exhaust </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr &raquo;</TD></TR><TR><TD CLASS="quote">Headers DC sport and exhaust supersprint </TD></TR></TABLE>
I really would not call that a quality exhaust setup. Personally I would worry about getting a much better exhaust system (if possible) before you worry about a few mm in the throttle body.
Old Mar 11, 2005 | 02:27 PM
Jowee's Avatar
He was trying to say nicely that your exhaust sucks and you should get a header with a 2.5" collector and a better exhaust.
Old Mar 11, 2005 | 04:14 PM
ITRacer121's Avatar
I got the 70mm STR and having problems with it working right so dont go with that one
but I have read that the 70mm is the biggest to go
Old Mar 11, 2005 | 10:27 PM
My exhaust --&gt;Header DC 4-1 2.5 and middle supersprint "2.5" and back supersprint Racing 2.5
And I put TB 70mm inside 68??too big????
Old Mar 12, 2005 | 04:51 AM
George Knighton's Avatar
H-T Order of Merit
JE 81.5 mm Pistons (CR--&gt; 12.2-12.3 for itr)
-AEM CAI
Apexi VAFC II
Hondata s100
You might get maybe 2 HP out of a TB at this stage. If somebody has one that he's offering you at an extremely good price, then fine.
Otherwise, it's not the best return of HP/dollars at your stage of development.
Honestly, a TB is the last thing most of us would do. I have a Spoon TB sitting in a box here, but it's just not a high priority getting it on the car for that couple of horsepower. It's not a bad thing to be doing...it's just one of the last things to do, after you've developed everything else.
I am not a big fan of the intake and exhaust you've chosen, and I'd respectfully suggest that you might see a better horsepower/driveability gain by changing the intake and header/exhaust and retuning.
How does the car dyno now?
Old Mar 12, 2005 | 05:15 AM
sneakychaos's Avatar
Where are you located? I'm not familiar with your location and I was wondering what types of products you are able to easily obtain? Seems like that might explain a bit of your exhaust problem..., or why you have chosen what you currently run.
Old Mar 12, 2005 | 05:22 AM
H-T Order of Merit
Default Re: Best throttle body size ?? (sneakychaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakychaos &raquo;</TD></TR><TR><TD CLASS="quote">Where are you located? I'm not familiar with your locationl....</TD></TR></TABLE>
His profile information is Lublin, Poland and AOL GetLoc says he is close to Katowice, Poland.
So I guess availability and local marketing could have a lot to do with his choices. Good guess.
Old Mar 13, 2005 | 11:53 AM
Default Re: Best throttle body size ?? (George Knighton)
Exhaut Supersprint the best in Europe very nice sound
I never change this products
Now I need TB and my question is which factory and bore I must buy!!!?for my set up
THX
lxrd_vtec
Feb 15, 2017 12:51 PM
UK_Luder
Apr 30, 2006 06:47 AM
krystianitr
Jul 11, 2005 10:20 AM
