Spoon Magnetic Drain Bolts
Just purchased a set of bolts, i'm not installed them yet but i'm abit concerned that the magent is nowhere near as strong as i expected??
It can pick up a stapple but nothing heaver..
I brought them from an offical spoon dealer in the uk with a good rep..
I guess what i'm asking is.. is this normal?
Modified by ibme_uk at 11:56 AM 3/3/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk »</TD></TR><TR><TD CLASS="quote">so you would not say that stronger is better?</TD></TR></TABLE>
well...i suppose that the stronger the magnet the more it would collect, but as reputable a company as Sp00n is i dont think you should have any concerns!
Rob...i am not sure if the stock oem plug is magnetic or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk »</TD></TR><TR><TD CLASS="quote">It can pick up a stapple but nothing heaver..</TD></TR></TABLE>
Are you expecting peices of metal larger than a staple to be lurking around in your oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Isn't the stock bolts also magnetic? </TD></TR></TABLE>
Nope, they isn't.
The tranny casing has a permanently fixed magnet in it, maybe that's what you're thinking of?
Nope, they isn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
Nope. The tranny casing has a permanently fixed magnet in it, maybe that's what you're thinking of?</TD></TR></TABLE>
Thats right it does...i forgot about that! After replacing my counter-shaft that bitch was all hogged up
Nope, they isn't.
thank you. I knew there was some sort of magnet in there,,,, Mine was so filled up with filings when the dealer rebuilt it it could no longer collect
Nope, they isn't.
The one i got can't pick up nothing heaver that a staple, and i recon with any oil passing over it the stapple would come off again...
I hope it never has to pick up anything bigger, but if it does I'd like it to keep hold of it.!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR »</TD></TR><TR><TD CLASS="quote">Seeeing is believing! I think I may pick up one of these Golden Eagle oil drain bolts.
I saw it in this thread.</TD></TR></TABLE>
lol
lol
Maybe something is wrong with your spoon plugs because my spoon plugs are really magnetic. There is a video floating around of a spoon plug hanging from the oil pan and someone is flicking it and it just moves all around but wont fall off. Mine do the same thing.
[img removed]
LOL.. I'd be praying that I don't find a piston, pin and rod attached to my drain bolt in my oil pan
I never really tested my spoon drain plugs before, but every tranny/motor oil change I can wipe a few tiny bits of debris off it, so I'm assuming it works well enough
Even my beater Pontiac had a magnetic plug stock and my R didn't.... What gives...
[img removed]
I bought skunk2 bolts so bwah! I think automatic trannys came with a magnetic plug, because I just flushed an automatic and it was OEM but magnetic. I was jealous.
Tranny magnet is removable, not permanently fixed. Earlier DC trans seem to have 2 square magnets in the rectangular holder, later seem to only have 1. either way, a magnetic drain bolt is far from necessary.
