does mugen cooling setup work?
Old Mar 3, 2005 | 06:36 AM
jsnm's Avatar
Default does mugen cooling setup work?
so does the mugen thermo and fan switch setup really help out or what?ive searched already and found no answer to this,just questions on install and what they do.im running FI and am just looking to run a little cooler.
Old Mar 3, 2005 | 07:00 AM
civicross's Avatar
Default Re: does mugen cooling setup work? (jsnm)
I'm sure it does, but for the $99123192 you spend on it you could build something yourself.
Old Mar 3, 2005 | 08:04 AM
Beatkidd's Avatar
I think youll only notice a difference if you track your car by temperturing staying constant
I know for fact that daily driving ive seen no change in temperature
Old Mar 11, 2005 | 07:07 PM
BROKENB2O's Avatar
honestly bro i didnt notice any change in temp on my car and i live where it gets to be 105 outside..but i guess its more of a bling factor...i have the thermo switch and fan switch on a fully built 12-1 cr-vtec ..i didnt see any change whatsoever
Old Mar 12, 2005 | 04:12 AM
jsnm's Avatar
yea,thats what i figured,i just needed to try something though,because the car runs fine with no overheatind,but every now and then it will just start to overheat for no reason.then ill start driving,hit some boost and it will go back to normal.would a blockguard make the car overheat occasionally?
Old Mar 12, 2005 | 04:32 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (jsnm)
Run some Redline Wetter Water, with a 10% coolant 90% water mixture. Put a switch on your radiator fan, so you can have it on whenever you want.
Old Mar 12, 2005 | 05:51 AM
jsnm's Avatar
Default Re: (LSVTEC 91 Civic)
im seriously beginning to think that this blockguard i put in a while ago is making my car overheat sometimes.it just doesnt seem to have adequate flow for the coolant,i attached a pic of it,its from KMS engineering.
90Rexx
16
Aug 12, 2009 03:29 AM
90Rexx
Aug 8, 2009 10:18 PM
SIVIC 3
Honda Civic (2006 - 2015)
12
Jun 3, 2008 05:53 PM
2fast2accord98
Feb 25, 2006 08:36 AM
Gong Show
Oct 15, 2002 06:10 PM
