Will 98-02 Euro R headlights fit 98-02 USDM Accords?
Old Mar 2, 2005 | 11:31 PM
slomob18b's Avatar
Default Will 98-02 Euro R headlights fit 98-02 USDM Accords?
Hey just wondering if these will bolt onto 98-02 USDM Accords without modification:
http://cgi.ebay.com/ws/eBayISA...59410
They look almost the same, but seems to be less curvy than the usdm ones. Does anyone know? thanks
Old Mar 2, 2005 | 11:53 PM
akhom's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (slomob18b)
Require slight modification.
Not a direct fit but very close.
Old Mar 3, 2005 | 12:37 PM
iam7head's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (akhom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akhom &raquo;</TD></TR><TR><TD CLASS="quote">Require slight modification.
Not a direct fit but very close.</TD></TR></TABLE>
dude, what are you talking about?
NONE of the body panel come close to fit.
and to answer your question, you'll need to cut/mold/paint your hood, fender, bumper, which pretty much everything you can think of.
I personally saw a 5th gen accord sitting in the bodyshop that already have the light mold in. it looks(and size wise) very close to 5th gen stanley jdm two piece light but again, they will not fit.
Old Mar 3, 2005 | 01:51 PM
slomob18b's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (iam7head)
Thanks alot guys. By the way did you need spacers to fit those 96 jdm itr wheels on your Accord iam7head? thanks
Old Mar 4, 2005 | 10:21 AM
iam7head's Avatar
the front wouldn't clear the caliper, the spec clearance i need is only 1-1.5mm but the thinest spacer i could found(in resonable price that is) is 3mm.
i think it goes the same as 4th and 5th gen, known a guy used a metal file to file away the caliper. that works too but it's a mess and i am pretty lazy
Old Mar 4, 2005 | 01:26 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
I personally saw a 5th gen accord sitting in the bodyshop that already have the light mold in. it looks(and size wise) very close to 5th gen stanley jdm two piece light but again, they will not fit.</TD></TR></TABLE>
I think he was asking if they will fit in 6 gen.
Old Mar 4, 2005 | 04:32 PM
z168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">Hey just wondering if these will bolt onto 98-02 USDM Accords without modification:
They look almost the same, but seems to be less curvy than the usdm ones. Does anyone know? thanks </TD></TR></TABLE>
ask the seller bro. he should know
Old Mar 6, 2005 | 12:45 AM
as_fast_as_u's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (z168)
the mounting holes are positioned in different location then 6th gen...see if you can find headlight measurment for the euro accord, my main concern is i think euro is a little smaller
Old Mar 7, 2005 | 02:36 AM
TakeiTeg's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (gude_f23a1)
they won't fit you'll need a lot of work. the guards at the side, the shape everything is all different.
JDM accord lights SiR-T/EuroR
USDM
Old Mar 7, 2005 | 10:08 AM
slomob18b's Avatar
Default Re: Will 98-02 Euro R headlights fit 98-02 USDM Accords? (TakeiTeg)
Cool just what I was looking for, thanks alot man!
Old Jun 30, 2010 | 09:48 PM
RAY_DA9's Avatar
Coming back from the dead...
Im guessing the answer is NO, but just to check w/you guys...
Will the SiR front bumper fit the 98-02 USDM front end...!? Just the bumper, keeping everything else the same...
Thanks...
Old Jun 30, 2010 | 11:38 PM
GlassJAw's Avatar
Whole car is more narrow than the USDM model, would most likely have to add a couple of inches in the centre for starters.
Old Jul 1, 2010 | 03:15 PM
nus_dogg's Avatar
No, the CF4 headlights will not fit the 6th Gen Accord. It will only fit the 5th Gen with modifications.
Not mine:
Some more:
Anything is possible if you put alot of money into it.
honda2112
Honda Fit
May 4, 2007 11:02 AM
subgeniusdude
Oct 27, 2005 09:28 AM
strepto
Acura TL, RL & ZDX
Aug 5, 2005 01:49 PM
Jeff2001R
Oct 7, 2004 01:31 PM
hondaZvic
Jan 27, 2004 04:58 PM
